Help, I'm cold!!!
Old Jan 30, 2010 | 09:36 PM
JDWalton's Avatar
JDWalton
that connector is a pain to mess with too. Just so you know, you need to be pushing down on the left and right side evenly, then push in the center of the back and as the arm sweeps down, it will back itself out. When you put it back in, make sure the arm is swung all the way down, then as you push it it, keep your fingers out of the way and the arm will lock itself back in, or at least almost all the way up. I did it while installing a radio, where it didnt really work right, and that arm wasnt all the way down when I had started to install it, creating a small stand off.
Short of that, if you replaced the resistor, and the motor, why dont you try simpler, like the switch itself. It might still be running just the same as it was before, however now that you replaced the older worn out motor with a new one, it just seems like it is blowing harder.
Good luck. If you go to the dealer out of waranty for it, there gonna charge you quite a bit.
Old Jan 31, 2010 | 10:02 PM
luvmygt's Avatar
luvmygt
Originally Posted by howarmat
its right under the radio behind the position ****
Oh ok, thanks again everyone! Gonna check it out as soon as I get a chance
4cylinderplus2
Oct 9, 2020 07:45 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Explosive
Oct 2, 2015 07:45 AM
RCS02v6
Sep 29, 2015 01:46 PM
Sixer4Life
Sep 28, 2015 07:05 AM
