Need wire color for accessory power source
Old Jul 25, 2005 | 12:56 AM
TNRedfire's Avatar
TNRedfire
Default Need wire color for accessory power source
I have completed a search here and now I ask this question to those who are familiar with the 05 wiring schematics. I need to know which wire(or wires) coming out of the fuse panel under the passenger kick plate is a key on accessory power wire(such as radio) to splice into for a switch to my fog lamps. I want the fog lamps to go off when the key is turned off. I have power to the lamps isolated with a relay under the hood. This is only for the power for the led on the switch.
Old Jul 25, 2005 | 11:11 PM
TNRedfire's Avatar
TNRedfire
Default RE: Need wire color for accessory power source
anybody???
Old Jul 26, 2005 | 12:04 PM
sowaxeman's Avatar
sowaxeman
Retired Moderator
I know its cheating - but anything of this low of current draw, I always just tie the wire directly into one side of the actual fuse as I push it in. So find a fuse that is only hot when the key is on, splice your wire about 3/4 ", spread it over one leg of the fuse and insert. If you are using a small 18-20g wire this should be easy to do.
Nurdyguy
Jan 20, 2025 04:38 PM
AMAlexLazarus
AmericanMuscle.com
21
Apr 4, 2020 02:16 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
cbird1177711
Sep 2, 2015 08:51 PM
