Question about GT/CS side scoop install
Old Feb 13, 2010 | 11:40 AM
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by bullitt ben
Hi,
There was no way i was going to make holes in the quarter panels, I used the factory 3m tape but added multiple layers of 3m tape at the locations where the fasteners would be and very (very) lightly scuffed contact areas with a fine scotch brite pad, cleaned areas
with solvent and installed the scoops, just make sure you align them correctly,
they have been on there for two years and no issues ,no way these are coming off,
remember, all other aftermarket scoops go on with 3m tape,
Dont scuff it, use the proper 3M 4298 adhesion promoter.
It promotes adhesion without scuffing the paint (WHY?????)
and helps the acrylic adhesive 'set'.
No holes needed.
Break off the assembly line 'alignment' pins
Attached Thumbnails Question about GT/CS side scoop install-4298adhesionpromoter.jpg
Old Feb 13, 2010 | 11:44 AM
Aziraphale's Avatar
Aziraphale
Originally Posted by 157db
Dont scuff it, use the proper 3M 4298 adhesive promoter.
I used the adhesive promoter and 3m tape only and mine have been on for about 2 years now without any problems. I wouldn't drill into the car.
Old Feb 13, 2010 | 12:01 PM
NJ3's Avatar
NJ3
I have a question for those that have bought GT/CS side scoops. I have found a place that sells them painted for $354, does this seem like a good deal? Anyone bought painted parts from Bangastang before?
http://www.bangastang.com/_e/Scoops/...oops_05_09.htm
Old Feb 13, 2010 | 12:29 PM
top00cat's Avatar
top00cat
i bought them from bangatang. paint match was spot on. it wasnt perfect but it was pretty good.i would say i was a satisfied customer and i am very picky about paint
Old Feb 13, 2010 | 03:55 PM
SaddleUp's Avatar
SaddleUp
I've gotten quite cozy with 3M tape over the past three years....never had any problems with it. In fact, when someone tried to steal my window covers, they couldn't get them off! Lol.
Old Feb 19, 2010 | 03:06 PM
157dB's Avatar
157dB
Cut & Paste Expert
My Roush 1/4 window covers are on there with 3M only and good luck
getting them off without wanting them to come off...
There are about a gizzilion different 3M tapes available...
Gets the right one for the job....
Old Mar 15, 2010 | 05:08 PM
MEK's Avatar
MEK
No holes needed.
I am getting ready to do this and I was just on 3M's site. It specifically says not to use adhesion promoter on the painted surface of the vehicle?
From 3M's site:
"Important Precautions and Recommendations
DO NOT… • Touch or contaminate the exposed adhesive surface of the tape.
• Let the tape sit around with the adhesive surface exposed.
• Apply the new tape over the old tape or tape residue.
• Use an adhesion promoter on the painted surface of the vehicle.
DO… • Use recommended 3M products for repair of all automotive BSMs and trim. "
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
bluebeastsrt
Aug 22, 2015 07:29 PM
kdryan
Aug 21, 2015 04:01 PM
MustangHead91
Aug 16, 2015 03:20 PM
