WTF...! GAS
It happens with my 07 very rarely but as others have said I turn the nozzle and it completes the fill with no problem. I think its probably a combination of things; the pump, the tank, and even the weather. But like I said its rare in my car, maybe 3 times a year at most.
There's a few TSB's plus a whole lot of threads. But the TSB "fix" doesn't really fix it. It has to do with the saddle type tanks. But don't fret because you're not alone.
There are a few work-arounds that work and in various combinations:
- Slow down fuel delivery as slow as possible, then speed up to find where it begins to kick off.
- Pull the pump nozzle out of the filler tube about half-way
- turn the pump handle 45, 90 sometimes even 180 degrees
- different pumps have different sensitivities. Find a pump that isn't so persnickity.
- Stand on your head and spit nickles
Found this related thread. I've never tried it, so I don't know how well it may work.
http://ratstangrestoration.com/05_mustang_tank.htm
WTF!
Use the search function....
And put your gas guage in RECOVERY MODE for bout 50 minutes of driving time....
Key on does not open up the vapor recovery system.
FAIL.
FAIL.
