Hood liner
Old Feb 15, 2010 | 05:29 PM
JimC's Avatar
Super Moderator
I've had mine off for a year now - it was always dirty and when I pulled it off to clean under the hood last time I just left it off. No problems, hasn't affected my paint, stripe or scoop at all.
Old Feb 15, 2010 | 06:03 PM
Nuke's Avatar
Nuke
Your hood will get much hotter sitting in the sun than it will from engine heat. If you want, remove it. No ill affect.
Old Feb 15, 2010 | 06:21 PM
wingman75's Avatar
wingman75
Jim is the paint in decent condition? I've had mine pulled partially off and the paint is not covering 100% of the under hood area. You can see through the paint in some areas its so thin.
Old Feb 15, 2010 | 06:33 PM
pascal's Avatar
pascal
S197 Section Modder-ator
I left mine off when I did the Shaker...
I'd had to cut a square hole to make it work but I don't like the way they look when they age, so off it stayed.
Old Feb 15, 2010 | 06:37 PM
RoushGT 1's Avatar
RoushGT 1
Originally Posted by night7519
I'm just south of Elizabethtown. How about you?
-Jim
Northern, Ky. i have a cousin that lives in E town.
Old Feb 15, 2010 | 06:41 PM
Stoenr's Avatar
Stoenr
Was just going to say this, some have reported not the entire under hood being painted.
No liner on my cowl hood for 3 year or so, no issues.
Old Feb 15, 2010 | 06:44 PM
rydeordie's Avatar
rydeordie
Had mines off for awhile with no problems either.
Old Feb 15, 2010 | 07:56 PM
night7519's Avatar
night7519
I would have to do something with the paint under the hood regardless. The paint on the leading edge of the liner has rubbed down to the primer already. So there would be some work to be done even if the hood is painted underneath.
-Jim
Old Feb 15, 2010 | 08:35 PM
TPony's Avatar
TPony
remove it without fear.
Old Feb 15, 2010 | 08:57 PM
JimC's Avatar
Super Moderator
-Jim
Mine wasn't finished under the liner - so I just used a "rattle can" to finish it up. I plan to get a new hood eventually (especially since my paint is bubbling on the edges) so didn't want to put a lot of time and money into covering up the primer.
