How do you change the front bulb on a 2010? (i cant believe i just asked that)
Sounds ridiculous right? Well I dont want to make a ***** up of it and discover there was an easier way. This is not HID btw.
Cue picture:
Do i have to remove the two red circled bolts and then pull the light unit out? Or am I over-complicating it?
Additionally, how do I remove the plastic lug, circled blue. Is this a case of just getting a flat head screwdriver and easing it out (that's what she said).
Cheers in advance
Paul
Cue picture:
Cheers in advance
Paul
Are you talking about the headlight bulb? You shouldn't need to remove anything to get to the headlight bulbs. For the fogs, you need to remove the 2 upper grill bolts so you can tilt the grill forward to get your hand behind the fogs.
Unless the apron on the '10 is larger than the '05-'09s.
According to the 2010 owners manual, it should not be a big deal:
From page 66:
Replacing headlamp bulbs
To remove the headlamp bulb:
1. Make sure headlamp switch is in the off position, then open the hood.
2. Disconnect the electrical connector from the bulb by depressing the retainer clip and pulling rearward.
3. Remove the bulb by rotating it counterclockwise and pulling it straight out.
Can you reach better from underneath the car?
From page 66:
Diode Dynamics
28
May 26, 2022 12:02 PM
inyadreems
Aug 21, 2015 09:10 AM
