Storage precedures
Old Mar 4, 2010 | 10:15 PM
Langor's Avatar
Langor
Question Storage precedures
Hello all,
Another unit was in need of more people so I volenteered to deploy. I will be leaving very shortly. My question is about how to properly store my mustang for a year. Any recommendations? I figure I should drive it almost out of gas before putting it in storage so it doesn't have a bunch of old gas in it. Any advice is much appreciated.
Old Mar 4, 2010 | 10:19 PM
KingB21's Avatar
KingB21
I dont know, but I filled my tank. Other than that I did nothing, it has been parked since Oct.
Old Mar 4, 2010 | 10:35 PM
ploe's Avatar
ploe
this is what i did before storing mine for the winter:
1. put the tires on rubber mats
2. put two dryer sheets inside (friend told me it absorbs any moisture)
3. almost empty tank
4. unplug battery
Old Mar 4, 2010 | 11:11 PM
Nuke's Avatar
Nuke
  1. Fresh oil/filter change. I'd put synthetic in the crankcase in lieu of the factory synthetic blend if the car is going to sit for 1 year or more. And be sure to change it soon after you put the car back in service.
  2. Add Sta-bil and fill the tank, then drive at least 10-20 miles to get the treated fuel thru the system. Otherwise, you need to totally run the lines dry which is NOT recommended. Any untreated fuel in the system may eventually degrade.
  3. Disconnect battery or connect a battery tender.
  4. Any moisture barrier between the tires and the concrete is good.
  5. Stuff wadded aluminum foil or steel wool in the exhaust openings to keep rodents out
  6. Optional to put dryer sheets or something in the cabin to keep it smelling "purty"
Old Mar 5, 2010 | 12:43 PM
nh3's Avatar
nh3
Wow, volunteered to deploy. Thats an act of bravery in itself. Thanks for your service and be safe.
Old Mar 5, 2010 | 06:41 PM
charliebrown266's Avatar
charliebrown266
+1 on what nuke said! always a full tank and sta-bil, don't leave it empty because that's how moisture will form in the gas tank!
baddog671
Jul 26, 2016 01:20 PM
sowaxeman
Jul 6, 2005 02:17 PM
SpazHairlip
Jun 23, 2005 12:44 AM
Scottsat
May 11, 2005 04:56 PM
MooseStang88
Jan 26, 2005 06:36 PM
