Battery issue - will it bump start?
Old Mar 13, 2010 | 01:53 PM
superslow's Avatar
superslow
Unhappy Battery issue - will it bump start?
I have a 2006 GT and per forums the batteries are ****. Well mine died suddenly last night and now there is NO juice to start it. I tried to bump start it a few times with no luck. I never had an issue bump starting a standard before, are these not bumpable? and yes, i was in 2nd.
Thanks in advance for the help!!!
Old Mar 13, 2010 | 03:42 PM
dominant1's Avatar
dominant1
isnt it better to buy a new battery?
Old Mar 13, 2010 | 04:01 PM
Slickvic_'s Avatar
Slickvic_
You still need to have enough juice to power the ECU, fuel pump and fuel injectors while you are push starting it.
Can the alternator do that while your being pushed? Let us know.
Buying a new battery will ensure a happy ending.
Old Mar 13, 2010 | 04:28 PM
157dB's Avatar
157dB
Cut & Paste Expert
Finding out what is causing the battery to die is first and foremost or your
new battery will be trashed soon enough and the buying new batteries cycle starts.
Check the alternator for proper output at the proper speed.
The battery is just the bucket. You need to be looking at the
pump (alt) and the amount of holes in the bucket (amperage draw)....
Old Mar 15, 2010 | 03:21 PM
superslow's Avatar
superslow
The only reason I was trying to bump start it was to get to the store to get the new battery. Well it wouldn't bump start and after a jump it started up. But get this, I get to Napa, get a battery and am heading home. As I am getting on the freeway the entire car shuts off, no power anything. I get to the side of the freeway and its done, no power at all. I swap the batteries right there and then it starts. I go to auto zone and they confirm the battery is toasted and they test the alternator and claim its putting out about 4 amps. So i get it towed to the dealership and have them look at it. They cant find anything wrong with it!?!?!?! Would the battery cause it to completely shut down like it did on the freeway? Mind you I drove for about 20 minutes then i died???
Old Mar 15, 2010 | 03:41 PM
Nuke's Avatar
Nuke
I believe it was the OP's OE battery that pooped the bed in which case I'd chalk up the battery failure to a 4 y/o stock, MotorCrap battery. But his post begs an answer to being able to push-start an S197 with a dead battery... Can you or can't you? I would have never thought you couldn't.
But then again, it's probably been about 20 or more years since I did.
Old Mar 15, 2010 | 03:51 PM
pentavolvo's Avatar
pentavolvo
car deff can be push started pending there is some juice, as in enough for the pcm and fuel pump to run
djbigskrilla
Sep 20, 2022 01:04 AM
importsmasher
Oct 9, 2015 04:42 PM
jjwinel78
Aug 17, 2015 03:34 PM
drumhedd2005
Aug 13, 2015 09:59 AM
'stangdude
Aug 12, 2015 01:27 PM
