Contents of a used S197 oil filter
The Cobra filter looks way cleaner than the other. Either the other car lives on a dirt road (lol) or it has much more mileage on it.
Engine wear cannot be determined by looking at the inside of the filter. Oil analysis will identify the composition of the wear particulars which provides info on WHICH internal component(s) is the culprit. But it usually takes multiple analysis to determine what's going on unless, of course, you have something catastrophic occuring. Think of it as a doctor doing blood analysis.
Damaging particles can be too small to be seen by the naked eye.
NOW can I have my fried chicken, Shella?
Your explanation has good reasoning and logic...and helps me to understand better. Nonetheless....I do think a super nasty-looking filter with lots of metal flakes would be reason for concern. I think I shall hack into mine.
Lol, no.....I would never know how to tear into one of those things....
I did hear, however, you could tell a lot about engine wear based on what the inside of a used filter looked like. I was curious as to what that meant. I suppose you would see metal flakes?
Your pictures show how much variation can be seen within the filters themselves. Very nice job.
I was wondering what would make you think "Boy, my engine is going to blow" just by looking at the filter.....does it look all black and nasty? Or is there more to it than that?
You're getting there Nuke Wait....I should tell you......I don't know how to cook.
NOW you're cookin', Shella. And BTW, I love it when you hack dirty...
The metal particles may not tell you exactly what is going on, but they would perhaps indicate a problem. I guess I am paranoid because I have always taken my car to a total stranger to do the oil change, and no one in the past has ever taken the time to look into this for me.
I stated that damaging particles CAN be too small to be seen by the naked eye; not that there wouldn't be particles large enough to be seen. And if you KEEP seeing metal particles every oil change, you have real problems. Typical wear particles are in the micron size range.
if you want a bit more info about what a oil analysis shows you , check out this thread I did some time ago...
https://mustangforums.com/forum/oil-...is-report.html
If you were to open up your filter and see something awful chances are you'd already be aware of it.
Just be thankful if you never changed oil in your car and see it come out white!
I did that on my Yamaha RZ350 and it was like milking my engine!
