Steeda Tri-Ax Shifter installation!!!!
Old Apr 14, 2010 | 01:46 PM
Range_Unllimited's Avatar
Range_Unllimited
Default Steeda Tri-Ax Shifter installation!!!!
Ok I'm changing out my Stock Shifter for a Steeda. The thing is I'm reading the reviews and people love the shifter but they say the noise level from the gears goes up a notch. I would like to know if anyone has any idea what type of insulation I should use to keep the noise level at a minium?
Old Apr 14, 2010 | 03:27 PM
Doogie65's Avatar
Doogie65
For my Pro 5.0 (which is almost identical to the Steeda), I did a couple things to help keep the additional NVH under control. This included using the stock front rubber bushing instead of the poly one, added an insulator made from thin plumbing rubber mat between the shift handle and shifter, and installed some dynomat between the rear mount and the body.
Mine works great and has very minimal extra drivetrain noise.
Old Apr 14, 2010 | 04:23 PM
SteedaGus's Avatar
SteedaGus
Former Sponsor
Our shifters now include additional measures to control NVH. Just make sure you order one direct from us, some older stock in the field may not have the new hardware.
Old Apr 16, 2010 | 12:36 PM
Range_Unllimited
Is there any way to figure out if i have one of the newer shifters from you all maybe a NSN or a certain part in the box. I order my steeda from AmericanMuscle not sure its the older model or not.
Old Apr 16, 2010 | 12:41 PM
Range_Unllimited
I take it I can pick up the rubber plumber matt and dynamo from a Lowes or Homedepot?
Old Aug 9, 2011 | 10:09 PM
lrvaught's Avatar
lrvaught
it comes with a dynomat,the only problem I am having with that shifter is trying to find an aftermarket shift **** (que ball style) like one from roush will not screw on.
Old Aug 10, 2011 | 03:27 AM
SteveB_RET's Avatar
SteveB_RET
Try GrabberPony.com for a queball style shift ****..
Old Aug 10, 2011 | 06:36 AM
chris09's Avatar
chris09
http://www.americanmuscle.com/steeda...509-white.html
best thing since sliced bread for the tri-axe.
carid
Jul 8, 2016 09:55 AM
vintageaion
Sep 8, 2015 10:45 AM
Webster454
Sep 7, 2015 04:59 AM
Sep 2, 2015 08:40 PM
