Sponsored by:
Sponsored by:
Roush hood scoop removal
Old 06-02-2010, 01:32 PM
rls82959
rls82959's Avatar
Default Roush hood scoop removal
My matte black Roush scoop suffered a bad Y shaped crack in a freak hail storm. Most of the hail was pea sized except for a few golf ball sized chunks. One of them hit my scoop.
I ordered a Satin Silver scoop and I will have it Friday.
After I remove the nuts underneath the hood, will the tape peel up pretty easily or will it be a hassle?
I will try the fishing line technique, but with the 7 studs sticking thru the hood, I don't know how effective the fishing line will be.
Any advice appreciated.
Thanks,
rls82959 is offline
Old 06-02-2010, 01:40 PM
siggyfreud
siggyfreud's Avatar
Spray some paint-safe adhesive remover before using the fishing line and you should be okay.
siggyfreud is offline
Old 06-02-2010, 02:51 PM
157dB
Cut & Paste Expert
157dB's Avatar
it will peel. roll it with your thumb.
3M emblem remover FTW at autozoner or peppem boys or oReallies...
no-no to the non-safe for paint goof-off or goo-gone carp.
or rubbing alcohol or peanut butter
you should not have to do the fishing line trick...
It aint stuck as well as you think its stuck.
The tape is only bout 3/8" wide and very sparse.
157dB is offline
Old 06-03-2010, 06:35 AM
rls82959
rls82959's Avatar
Thanks for the input. The tape isn't very wide. 8x240mm in the rear and 12x250mm on the sides. My fear is bending the damn hood when I pull up on the scoop. 3M emblem remover eh? I'll check Autozone.
Rear Blackout gone. Satin Silver scoop this weekend.
rls82959 is offline
11-18-2015 01:34 PM
zachary1988
09-18-2015 11:17 PM
09-10-2015 07:23 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Roush hood scoop removal
