DTC code P0 622???
Old Apr 15, 2010 | 08:54 PM
solidsnakegt89's Avatar
solidsnakegt89
Default DTC code P0 622???
my check engine light is on with 3 codes going off. P0 153 and P0 133 i know those are O2 sensor codes not worried about them theres a reason why those are going off but now i have a P0 622 code going off I think it has something to do with wiring harnesses??? not sure anyone know what the issue may be?
Old Apr 15, 2010 | 10:43 PM
SpartaPerformance's Avatar
SpartaPerformance
P0622 - Generator Field Terminal Circuit
Old Apr 15, 2010 | 11:33 PM
solidsnakegt89
Uh how do I fix that problem? Why would that go off?
Old Apr 16, 2010 | 08:07 PM
solidsnakegt89
BUMP. no one knows how to fix this problem fellas?
Old Apr 16, 2010 | 08:25 PM
hammeron's Avatar
hammeron
solidsnake, i think i looked at this code yesterday. one
way to go about fixing this is to disconnect the battery,
then check the alternator wiring.
the wires in question are the wires that plug into the
connector on the alternator itself.
Old Apr 16, 2010 | 09:14 PM
solidsnakegt89
thanks hammeron i will do this tomarrow and see what the results are.
Old Apr 16, 2010 | 09:30 PM
hammeron's Avatar
hammeron
HTH
just do a visual and make sure those wires look good
all the way to their destination, no shorts or opens.
turbo 2.8
May 5, 2025 09:48 AM
specialized101
Nov 9, 2012 08:56 AM
