cat delete PLEASE HELP
Old Apr 18, 2010 | 01:15 AM
08blackoutstang's Avatar
08blackoutstang
Default cat delete PLEASE HELP
alright i am doing a cat delete in my exhaust here coming up soon and i was wondering if this will through a code with my O2 sensors and if so what will the affect be on my car... like will it cause my engine to run weird?
Old Apr 18, 2010 | 01:37 AM
OIIIIO's Avatar
OIIIIO
Don't do it... IMO, it will sound like **** on a sixxer.
Old Apr 18, 2010 | 08:13 AM
jwog666's Avatar
jwog666
it will set a code for cat efficiency(check engine light on). it will have no effect on driveability, but it will sound like crap, and you will gain little to no performance. there is a common misconception that if you remove the cats that you will gain lots of HP, but thats not the case.
Old Apr 18, 2010 | 09:26 AM
08blackoutstang
i am not JUST removing cats, i know that would have sounded like crap... i am doing pypes true duals with cat deletes OR X pipe and muffler deletes with JBA headers, it'll sound good, i was just trying to figure out if it will affect drivability... like cause the engine to run lean....
Old Apr 18, 2010 | 09:54 AM
Linde's Avatar
Linde
You have two options.
1. Use a tuner to shut off the rear OS sensors.
2. Use MIL eliminators.
// Daniel
Old Apr 18, 2010 | 10:08 AM
NOLA26's Avatar
NOLA26
Like everyone said, without a tune, you will throw a code. Will that setup sound good on a six? I would think it would sound like a ricer with a coffee can muffler?
Old Apr 18, 2010 | 11:39 AM
rdsx18's Avatar
rdsx18
I said it in your last thread and I will say it again, not being an *** but I do not think that setup will sound good at all. It will be loud, but won't sound good.
Old Apr 18, 2010 | 11:48 AM
ronniegibson1978's Avatar
ronniegibson1978
i have long tubes on my car an or'h pipe...and i ran pypes muffler deletes..let me tell ya, it sounded like a nascar which was cool when you pulled up next to a jaguar or bmw. but i had to put mufflers back on to get some backpressure what so ever
Old Apr 18, 2010 | 11:47 PM
08blackoutstang
we will see after i get the rest of my pipes, if anything and it does sound bad i will switch everything back and forth, nbd
Old Apr 19, 2010 | 06:19 AM
usc49erfan's Avatar
usc49erfan
// Daniel
actually only one, the tune, mil eliminators are not used in the s197, and for the op you will probably need o2 extensions, but you will def. need a tune with the header install and may i suggest bama a lot of people, myself included, had problems with the code from the jba headers but doug fixed it on his first try
