clutch
Old Apr 21, 2010 | 02:31 PM
luis05gt's Avatar
luis05gt
Default clutch
what are the signs of a clutch going bad will it make a grinding noise while going into gear in 1st
Old Apr 21, 2010 | 02:51 PM
candymanjl's Avatar
candymanjl
clutches typically don't grind but if it's not disengaging fully when you try to shift then it'll cause your tranny to grind.
typically when a clutch is going the most noticeable sign it that it won't hold the power. so if you have it in gear with the clutch fully engaged if you floor it and it doesn't hold then you have a problem.
if it holds the power but you have trouble going in and out of gear it could be something else. on my S2000 a common issue was needing to bleed the clutch valve thingy or you would have trouble fully disengaging the clutch to shift gears.
Old Apr 21, 2010 | 03:09 PM
luis05gt's Avatar
luis05gt
this is the problem i took it for warranty work on my second gear syncro they said the 1st was also messed up i asked them are u sure cause it works fine to me so they went ahead and did it now i have problems with my first gear syncro it wont go in right and sometimes it wont go into first gear going 10mph and they said its my clutch but last week they told me my clutch is fine
Old Apr 22, 2010 | 08:53 AM
kevinmalec's Avatar
kevinmalec
in my ford explorer my springs went bad in my clutch and had to be replaced. i could feel and hear weird noises with the clutch pedal when I pushed it down with my foot. I never heard any grinding noises though.
Old Apr 22, 2010 | 09:22 AM
HypromanGT's Avatar
HypromanGT
Holy cow, it sounds like you need to get to a different dealer...
Are they now going to tear into it again to try to fix it on their dime?? I sure hope so...
I would seriously consider getting help from a dealership that does diagnostic work before blindly replacing parts, but that just my opinion.
Old Apr 22, 2010 | 12:55 PM
luis05gt's Avatar
luis05gt
__________________
well it turns out that now my clutch and flywheel are gone according to them so they wont go into the syncrhos until i replaced it,i told them why did u tell me it was fine a week ago and he had no answer,i have to pay 2,000 to get it replaced and once its replaced if it still grinds then they will check the syncrho
Old Apr 22, 2010 | 02:16 PM
SilverHoss's Avatar
SilverHoss
They are full of spit. When a clutch goes bad, it will start slippin'. You can test this by going down the road in one of the higher gears, about mid-RPM and punch the gas-if the engine speeds up and the car don't, it's the clutch. Bad clutch will not cause you to grind going into gear. now if you have a pilot bearing going bad, or it was damaged when they worked on the car before, that will cause the clutch to never fully disengage, casuing the grinding (it causes the tranny input shaft to spin with the flywheel) OR , if there is an issue with the clutch hydraulics (like if they didn't bleed the hydraulics when they worked on it), that will also cause the issue you describe. But not the clutch.
But HOLY COW, $2000.00 !! you are joking, right? Because that is way way overpriced for a clutch job. All clutch parts plus flywheel can be bought for less than $300.00 easy. That 2,000 is just an outright ripoff.
Check anywhere - that price is pure BS.
They are just trying to make you pay for the repair one way or another...
Old Apr 22, 2010 | 02:24 PM
candymanjl's Avatar
candymanjl
it's probably more in labor than in parts, that's how they got to $2,000.
Old Apr 22, 2010 | 02:46 PM
luis05gt's Avatar
luis05gt
yeah screw them i have to pay to get it out so i can fix her at some shop it was gonna cost me 580 but i got them down to 150 but i dont know what clutch to go with i still have a feeling that the syncrho is broke sometimes when i was at a light and tried going into 1st it would get stuck halfway it would take a lot of strength to get it in is there a site where i can buy an oem clutch
Old Apr 22, 2010 | 09:20 PM
jerjan's Avatar
jerjan
labor should be about 10 hours flat rate or less @ $95 per hour plus parts. Do the math., They are ripping you off at $2000.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
