too much body flex?
Old Apr 28, 2010 | 11:29 AM
tlpvt's Avatar
tlpvt
Default too much body flex?
Hi guys/gals,
07 GT - noticed that rear end started squeaking every time the rear part of the car is flexing ; for example, when parallel parking one rear wheel gets on a higher curbside and the whole rear end make a noise as if it is flexing. i don't think it is shocks/suspension. seems like the body is flexing and makes these sounds.
I was told that adjusting the trunk lid position may help with the sounds... ;-)
any thoughts/suggestions?
Old Apr 28, 2010 | 12:43 PM
SirKnightTG's Avatar
SirKnightTG
Muffler bearings are getting dry. http://kalecoauto.com/index.php?main...products_id=10
Old Apr 28, 2010 | 01:46 PM
zkiller's Avatar
zkiller
Id bet it isnt body flex at all when parking. I can launch my car at the dragstrip at 3000 RPM and not get an body flex..
Try lubing all the rear suspension bushings.
Old Apr 29, 2010 | 10:12 AM
JCON's Avatar
JCON
Originally Posted by SirKnightTG
LOL
Raise your car on 4 jack stands, then slowly lower one stand. If the car balances on three points then there isn't much flex. if as you lower it keeps contact on all four stands than you need to stiffen it up.
Old Apr 29, 2010 | 11:57 AM
2cokeman's Avatar
2cokeman
must sell a ton of those??
Old Apr 30, 2010 | 09:40 PM
tlpvt's Avatar
tlpvt
Originally Posted by JCON
LOL
there is ALWAYS some body flex - say you jack up one front wheel and compare distance to the ground between front and rear jack points on that side - I am positive there will be a difference between the two. No chassis is 100% stiff, not possible. just some cars are more flexible than others.
Old Apr 30, 2010 | 09:45 PM
tlpvt's Avatar
tlpvt
don't think it is the suspension. i did a little experiment - backed onto a curb with the trunk OPEN and didn't hear much squeaking. Looks like the trunk stoppers are rubbing (which is indicative of some body flex :-)\
guess i need to figure out how to adjust the trunk lid setting...
Old May 1, 2010 | 06:39 AM
JCON's Avatar
JCON
My brothers 300zx didnt flex, we checked one day when we raised it and then lowered one stand and noticed it didn't move at all
Old May 1, 2010 | 09:18 AM
157dB's Avatar
157dB
Cut & Paste Expert
During parking, your springs will take all the flexing
leaving the body totally static.
Its suspension noise.
Unless Ford forgot a few hundred spot wels on the rear body...
What suspension mods have you done?
Ever loosened a suspension bolt back there?
There is always some chassis flex when jacking one corner by the body
but you would need a 0.001 dial indicator and a really big surface plate to see it...
Not easily visable with the naked eye and a tape measurer...
Old May 2, 2010 | 11:54 AM
JCON's Avatar
JCON
But I have a special naked eye!
I do agree there had to be some body flex while load is shifting but it was very minimal compared to other cars where, tape measure or not you can see the car is screaming.
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
RCS02v6
Sep 29, 2015 01:46 PM
GLOCKer
Sep 28, 2015 07:36 AM
2poor4u2
Sep 26, 2015 11:08 AM
