how to reprogram s197 keys?
Old May 10, 2010 | 05:37 PM
raywang5's Avatar
raywang5
Default how to reprogram s197 keys?
i lost one, and i only have one left right now, and then i got the new one from ebay, and follow the instructions to reprogram it, but it doesnt work. do i need to go to some local dealer to do that only? or i miss some steps when i do that? (the new one is a cut key, same look as mine)
Old May 10, 2010 | 05:55 PM
keester's Avatar
keester
Yep If you only have one. The dealer has to do it. shop around. Previous owner only could find one key. Dealer charged me $95 total. I think the program was around $75 and the key $20 last week. Once you have 2 you can do more yourself.
Old May 10, 2010 | 11:52 PM
raywang5's Avatar
raywang5
alright. thx bro. looks like i need another 75 bucks to finish my work..btw, only the key or including the remote control also?
Old May 11, 2010 | 02:48 AM
Diabolical!'s Avatar
Diabolical!
Most locksmiths now have the machine to program the Ford keys for a hell of a lot cheaper than Ford dealerships. My local Ace Hardware charges less than 50 bucks, and that includes the new key. You can program the remote yourself following these directions:
Get in the car and close the door. Put a working key in the ignition. Lock then unlock the door using the switch on the driver's side. Cycle the key 8 times from "off" to "on" rapidly (without starting the engine) ending with the key in the "on" position. If you did this step correctly, the door locks will automatically cycle to lock then unlock. At this point, press the lock button on ALL of the remotes you plan to use on this car (if you only press the new one, then the old one will no longer work). Remove the key from the ignition. Test each remote for function.
While I'm at it, I might as well post the method for programming a new key if you have TWO working keys. First, have the NEW key mechanically cut. Get in the car and close the door. Put the first WORKING key in the ignition and turn the ignition to "on" (without starting the vehicle) for 3 seconds. Turn key to off and remove. Quickly place the second WORKING key into the ignition and turn the ignition to "on" (without starting the vehicle) for 3 seconds. Turn key to off and remove. Quickly put the NEW key into the ignition and turn key to "on" (without starting vehicle) for 3 seconds. Turn key to off and wait 15 seconds, then remove. WAIT TWO MINUTES and test all keys for function.
Old May 15, 2010 | 05:41 PM
07blkgt62's Avatar
07blkgt62
Thanks Diabolical, I'm going to give it a try.
Tivo304
Aug 28, 2023 12:19 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
piotrek53
Oct 13, 2015 06:54 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
logan409
Sep 26, 2015 07:43 PM
