removing spring isolators
Old May 11, 2010 | 09:42 AM
etnoats's Avatar
etnoats
Default removing spring isolators
Anyone remove their spring isolators to get a little extra drop? If so how much did you get? I have the steeda sport springs but want a little bit more drop but dont want to change springs. I like how the ride and the fact that they are linear rate springs. running d specs so I have some control over the ride also.
Old May 11, 2010 | 02:23 PM
Z06 Killer's Avatar
Z06 Killer
If you remove the isolators then you are going to get a lot of metal on metal action and you will have more creaks, moans and pops than a middle aged lady of the night!
Not to mention the springs would fit in the cups loose and will cause all kinds of alignment issues.
Old May 11, 2010 | 08:24 PM
etnoats's Avatar
etnoats
good point, thanks.
Old May 11, 2010 | 09:22 PM
siberian.mist's Avatar
siberian.mist
I forgot to put the spring isolators in over a year ago, I have steeda sport springs and dspecs. I have no creaks, moans, pops, and had no trouble being realigned. Plenty of miles on beat up Minnesota roads and I have no problems.
Old May 13, 2010 | 10:24 AM
etnoats's Avatar
etnoats
front and back? Any other suspension mods? Could you measure the measure the height to top of the wheel wells for me so I can see how much yours is different?
Old May 13, 2010 | 11:26 AM
siberian.mist
i would not go through the trouble of taking all of them off, it will gain you 1mm more of drop if that. im just stating if you forgot to put them on, i think it will be ok.
bmr lca's, bmr adjustable panhard, bmr camber bolts, tokico dspecs, steeda sport springs
Old May 13, 2010 | 11:53 AM
baddog671's Avatar
baddog671
How much did the steeda sport springs drop your car? Internet says 1" front, 1.25" rear, but I know they are rough numbers...
Old May 14, 2010 | 10:41 AM
siberian.mist
i didnt measure but i believe its a little more than those numbers
Old May 14, 2010 | 12:10 PM
baddog671's Avatar
baddog671
I'm looking to do 1.5"front/2"rear once I move down south. Think BMR still makes the 2" kit
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
Dathan
Oct 5, 2015 05:52 AM
mungodrums
Sep 28, 2015 10:54 PM
