How to determine proper offset??
Old May 16, 2010 | 07:31 AM
Norm Peterson's Avatar
Norm Peterson
Originally Posted by 157db
Explain the last two statments in detail, Norm?
It does not make sense to me and that means most
others wont get it either...
They are crude (but pretty good for most alloy wheels) formulas to solve either for offset when backspacing and advertised wheel width are known, or for backspacing when you know the offset and advertised wheel width.
You need the added 1" because the offset measurement doesn't care what it is, but backspacing does include the thickness of the inside flange. It's an approximation - OE Ford wheels have at least one flange that's slightly thicker. But it's good enough until you're worried about sixteenths of an inch being the difference between clearing and rubbing the wheel itself. Tire clearance is another matter entirely.
The sign for the offset measurement matters.
Example 1: 18 x 8.5" wheel, 6.80" backspacing. Offset = 6.80 - (8.5 + 1)/2 = +2.05", or +52mm
Example 2 18 x 8.5" wheel, 4.50" backspacing. Offset = 4.50 - (8.5 + 1)/2 = -0.25", or -6mm
Example 3 18 x 9.5 wheel, +45mm offset (+1.77"). Backspacing = 1.77 + 0.5 x (9.5 + 1) = 7.02"
Example 4 18 x 9.5 wheel, -13mm offset (-.51"). Backspacing = -0.51 + 0.5 x (9.5 + 1) = 4.74"
Norm
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
Sep 25, 2015 06:42 PM
gagemcc
Sep 22, 2015 09:43 AM
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
