help with wideband a/f o2 sensor
Old May 19, 2010 | 08:47 AM
MUSTANGEXPERT's Avatar
MUSTANGEXPERT
Default help with wideband a/f o2 sensor
where do i mount the o2 sensor for my gauge?
Old May 19, 2010 | 10:53 AM
Diabolical!'s Avatar
Diabolical!
I had an exhaust shop tap into the driver side exhaust just behind the manifold and weld in the bung. Charged me $10.
Old May 19, 2010 | 02:09 PM
candymanjl's Avatar
candymanjl
I'm going to mount mine as close to the factory location as I can, figure Ford picked that location for a reason
Old May 19, 2010 | 02:25 PM
onederful100's Avatar
onederful100
http://www.tricktuners.com/forums/showthread.php?t=25
Old May 19, 2010 | 05:38 PM
candymanjl's Avatar
candymanjl
Originally Posted by onederful100
only thing I disagree with in that link is the driver's side placement. you never want to have the sensor on the underside of the piping or moisture can settle on the sensor and cause it to die after a relatively short amount of time.
Old May 19, 2010 | 06:34 PM
Diabolical!
Agreed. You should never mount an O2 sensor on the underside of an exhaust pipe. However, that pic is from an SN95. The S197 has much more room to properly mount the wideband O2 sensor on the driver's side.
Old May 19, 2010 | 07:26 PM
onederful100
if you look at the pic closely the pipe is coming down so its not under the pipe bc its at an angle, so essentially its on the side.
VistaGT's Avatar
VistaGT
Mine's mounted on the drivers side rear factory location...It has the proper angle to avoid condensation
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
samseed101
Jan 31, 2007 09:48 AM
Boostaddict
Jan 15, 2007 06:26 AM
ruger311
Nov 13, 2006 03:54 PM
ruger311
Nov 7, 2006 11:06 AM
