SEQUENTIAL PROBLEM
Old May 20, 2010 | 01:51 PM
antipeterleague's Avatar
antipeterleague
Default SEQUENTIAL PROBLEM
ok so recently i discovered that 2 of my passeneger side tail lights were out. shortly after, the sequential on the driver's side stopped working and it only did the normal 2 panel flash.
i decided to replace all 6 bulbs. when i finished, the driver's side sequential worked fine, but none of the bulbs on the passenger side were firing. so i took the tail light out and disconnected theh arness and connected it again, and it worked fine. at that point i ptu the nuts back on the assembly.
now the passenger side stopped working again. so i was wondering if anyone knew that trick to "reset" the lights or whatever. or maybe tell me if they had similar experiences?
Old May 20, 2010 | 02:03 PM
Unleashedbeast's Avatar
Unleashedbeast
What brand of kit do you have? That would be helpful to other members.
Old May 20, 2010 | 02:07 PM
antipeterleague
i believe they're webelecric
Old May 20, 2010 | 03:49 PM
Nuke's Avatar
Nuke
I've seen issues with dirty harness connections. The fact that you resolved one side by disconnecting and reconnecting seems to confirm that was an issue for you. Before anything else, try disconnecting the side that's not working and spraying both halves of the connectors with contact cleaner. IMMEDIATELY reconnect and disconnect the halves multiple times to "wipe" the contacts. If that doesn't resolve the issue, then at least you can rule out those contacts.
Old May 20, 2010 | 03:51 PM
antipeterleague
by dirty, do you mean noticeably? cause i thought of that but when i disconnected them they were both clean. it's such a ****ing hassle to remove those tail lights....haha
Old May 20, 2010 | 04:06 PM
Nuke's Avatar
Nuke
Contacts can form a very thin, almost non-perceptible oxide layer. It wouldn't surprise me if exhaust gases build up in those panels to some degree.
All you need to do is remove the panels to access the connectors.
Old May 20, 2010 | 04:10 PM
157dB's Avatar
157dB
Cut & Paste Expert
If they appear clean, they are clean enough.
Plug n Play or splice in kit with IDC connectors?
Old May 20, 2010 | 10:38 PM
antipeterleague
ok so i disconnected and reconnected the harness and now it works perfectly...wicked! didn't even have to remove the tail light to do that.
Old May 21, 2010 | 12:45 AM
siggyfreud's Avatar
siggyfreud
Sounds like it was gremlins.
Old May 21, 2010 | 08:15 AM
07 Stang's Avatar
07 Stang
Maybe the connections got loose?
