Changing from 96R to 40R battery
Are these the only things that need changing when switching from the 96R (small) to 40R (large) battery?
1. Remove a couple of plastic pieces from the existing battery tray to accommodate the longer battery.
2. Install a heat shield designed for the longer battery.
I think that everything else (e.g., tray, hold-down bolt/clamp) is the same for both batteries.
Thanks.
Thanks.
Thanks.
Thanks.
My original Motorcraft battery starting dying after about two years, and was replaced under warranty. If the replacement does not last at least three years, I will probably go with an Interstate battery. As far as I know, Interstate does not sell a Group 96R battery.
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
