Quick suspension question
Old Jun 18, 2010 | 04:28 PM
Allstar's Avatar
Allstar
Default Quick suspension question
So I just got my springs (sportlines) and wanted to do the install but I wasn't sure if I needed a spring compressor? anybody know if his is needed if im just installing springs?
Old Jun 18, 2010 | 04:45 PM
Dogg's Avatar
Dogg
I've not worked on any Mustangs, but you almost always need a compressor to get the springs in/out.
Old Jun 18, 2010 | 07:14 PM
ShaneM's Avatar
ShaneM
Def need a compressor, the fronts shocks and all come out with the springs installed. also you have to replace the shock mounts too. they are one time use. You will end up with clicking in the front end if you don't. The GT500 parts are like $60 if i recall. i lowered my 05 with those springs and also needed the longer camber bolts to get the alighnment correct. AND FWIW, you might find that the ride is realyl rough with those springs and stock shocks. i had the tokino (tokinco or whatever) blues with my 05 and it rode horribly, very very rough and jittery.
Old Jun 18, 2010 | 08:40 PM
SpartaPerformance's Avatar
SpartaPerformance
Yes you need a spring compressor for front struts. For the rear you can unbolt the rear shock and let the rear hang low enough for spring to fall out, just remember to unbolt the ABS sensor wire from the frame bracket 1st
Old Jun 18, 2010 | 09:23 PM
2005Redfire6's Avatar
2005Redfire6
The shock mounts being one time use is debatable, I know of a few pepole that reused them and they work fine with no clicking.
OP,Sportlines is one hell of a drop, plan on trimming down your bump stops too.
tmdm
May 2, 2021 02:49 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
