windshield washer fluid
Old Jul 9, 2010 | 10:31 PM
bojanglesowner07252's Avatar
bojanglesowner07252
Default windshield washer fluid
i cant get anything to spray out. It is full of fluid cause i went to top it off and it was already full. I never really used it since I bought it in august....what should I check for?
Old Jul 9, 2010 | 11:26 PM
Alec's Avatar
Alec
Do you wax the car? One time, wax got in the nozzles and dried up and I couldn't get anything to come out. Cleaned it out with a needle.
If not, maybe something came unplugged
Old Jul 9, 2010 | 11:27 PM
3fan's Avatar
3fan
Go under the hood liner and take the line loose and see if it sprays. Be careful the hoses and joints get brittle and will break. Is the pump working.
Old Jul 9, 2010 | 11:28 PM
3fan's Avatar
3fan
I hate having the sprayers on the hood for that reason. Dang fords.
Old Jul 10, 2010 | 07:31 AM
bojanglesowner07252
I dont really wax it, but i dont think the pump is working....like how when u use it u can here it spraying, when i go to spray it absolutely nothing happens, no noise either. If it is a pump, what happens next?
Old Jul 10, 2010 | 08:43 AM
Nuke's Avatar
Nuke
You should be able to pull the lines from the nozzles under the hood to see if the fluid flows. If it does, then the nozzles are clogged. If not, then work your way back. Also, you should be able to hear the pump running when you try to spray. If not, check the fuse.
Old Jul 10, 2010 | 11:18 AM
bojanglesowner07252
thanks alot for the help...i will soon figure it out, just got off work
Old Jul 13, 2010 | 09:51 PM
3fan's Avatar
3fan
Hey did you fix it. My dad stopped by the house he has a 05 f150. He said only one of his nozzels worked. After a quick look under the windsheild cowling there is a y fitting that takes thre line from one into two and it was dry rotted and cracked. It was squirting washer fluid down into the engine area. Just thought it might be helpful. We were able to piece something together and replaced the cowl and all fixed.
Old Jul 14, 2010 | 07:29 PM
bojanglesowner07252
no i got busy and never worked on it yet....but its gotta be the pump because u hear nothing when u try to use it.. How /where do u check the fuse for this?
jma2
Jul 10, 2023 01:00 AM
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
wraith777
Sep 28, 2015 10:49 AM
Sep 25, 2015 06:42 PM
