Idle problem?
Old Aug 1, 2010 | 12:54 PM
  #21
VistaGT's Avatar
VistaGT
Did you use MAF cleaner on the MAF or throttle body cleaner? There are separate cleaners for this as the MAF is a delicate piece.....
Other than this you can try reloading the cars tune and if that doesn't work you can disconnect the battery to reset the car.
After this call brenspeed, but it's good you'll have had tried these before you call
Old Aug 1, 2010 | 02:41 PM
  #22
kevinmalec's Avatar
kevinmalec
Yes, I used the throttle body cleaner to clean the Tb and I used the MAF sensor cleaner to clean the MAF sensor. It was very simple to take off the TB, all you have to do is take off the CAI intake inlet tube and then unscrew the 4 bolts that hold the TB on. I used the TB cleaner and a rag and Q-tips to wipe the gunk off the throttle body. This issue took place before I installed the CAI and the tune, so this is an issue that is not related to the tune.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
