Another problem......
Old Sep 9, 2010 | 06:59 PM
Lil_Chef's Avatar
Lil_Chef
Default Another problem......
starting a couple days back i have had a "thumping" noise from what i believe originates from the passenger side front corner. This is a noise that is proportional to how fast i am going for example:
at 20 mph it is a thump..........thump.............thump........Thum p
then at 40 it would be thump..thump..thump..thump
and whenever i am pushing my brakes the noise disappears. there is no steering wheel feed back that i noticed... i am seriously stumped on this one.......
Old Sep 9, 2010 | 08:14 PM
2cokeman's Avatar
2cokeman
Brake-bearing related??
Old Sep 9, 2010 | 09:05 PM
Nuke's Avatar
Nuke
I'd think a bearing and a tire problem wouldn't stop thumping when the brakes are applied so...
Old Sep 9, 2010 | 09:15 PM
Lil_Chef's Avatar
Lil_Chef
bearing? what are you referring to? and how would it have failed so quickly?
Old Sep 9, 2010 | 09:20 PM
Unleashedbeast's Avatar
Unleashedbeast
I was going to say....you have a rock in your tire tread, but then you said it stops when you push the brakes. DOH!
Thought I had the cure.
Old Sep 13, 2010 | 12:00 PM
Lil_Chef's Avatar
Lil_Chef
the problem is still persisting. i noticed that the noise only occurs on some roads, on others the car is whisper quiet.
i just got back from a track weekend and there were no "physical" problems when driving at the limit, the noise is just ridiculously annoying. any suggestions are appreciated
Old Sep 13, 2010 | 12:35 PM
WeinerDog's Avatar
WeinerDog
Have you checked your lug nuts? Loose lugs will do exactly this.
Old Sep 13, 2010 | 01:28 PM
Lil_Chef's Avatar
Lil_Chef
yup got them all torqued to 92 ft-lb for the track. since they are cheapo pep-boys lug nuts maybe they have "worn out" ?
Old Sep 22, 2010 | 05:26 PM
Lil_Chef's Avatar
Lil_Chef
well i replaced the lug nuts, tightened everything on the passenger side and cleaned both the rotor and the hub to which it sits on.... and i still get noise. i really dont know what else it could possibly be.
Old Sep 22, 2010 | 06:29 PM
vixr's Avatar
vixr
grasping at straws here, maybe the tire has some sort of failure. Move it to the back and see if the thump follows the tire?
