BBK Headers Installation question?
Old Sep 12, 2010 | 08:42 AM
StayingFit24_7's Avatar
StayingFit24_7
Default BBK Headers Installation question?
Is engine removal necessary to install a header?
Old Sep 12, 2010 | 09:34 AM
marcuskeeler's Avatar
marcuskeeler
Nope, but you will have to remove some parts, the more you remove the easier it is.
At the minimum you need to jack the motor off the mounts and remove those. the steering shaft has to go as well. Some folk remove the starter (I didn't).
Old Sep 12, 2010 | 09:58 AM
Soldier GT's Avatar
Soldier GT
It may sound like a pain but it will make the install alot easier. Also a bit of advice I would buy better gaskets. I had a bad experince with the gaskets that came with my headers.
Old Sep 12, 2010 | 11:48 AM
Cal26Stang's Avatar
Cal26Stang
You have to, have to, remove the motor mounts...it makes the install so much easier, also, make sure you shave down two of the bolts or else you'll run into problems
Old Sep 12, 2010 | 06:58 PM
marcuskeeler
Removing the motor would make a whole raft of jobs easier but why would you? LOL
I never had a problem with the gaskets so far but I did end up having to run jam nuts onto the studs where the headers bolt to the downpipe, mine originally kept coming loose.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Calizic
Aug 28, 2015 01:46 PM
91StangOwner
Aug 20, 2015 11:34 PM
Hillbilly1968
Aug 19, 2015 12:03 PM
dragman72
Aug 9, 2015 12:54 AM
