Drivetrain or Suspension?
Old Sep 16, 2010 | 10:46 PM
UpTo11's Avatar
UpTo11
Default Drivetrain or Suspension?
I'm going to do something major with my car in the next couple of weeks, and it's either going to be lowering 1.5" with new shocks, struts, and sway bars, or a one-piece aluminum driveshaft with 4:10 gears. Some of you folks have done both, and if I may ask, which one of these have you enjoyed more? I am at a crossroads, so don't tell me to go with whatever I want or anything. Looking for opinions. Thanks.
Old Sep 16, 2010 | 11:38 PM
grabber blue gt's Avatar
grabber blue gt
Depends on what you are using the car more for. Are you going to take it to the drag strip or a road course type? For the strip you would want the 4.10s and drive shaft and everybody that installs the 4.10s loves them.
Old Sep 16, 2010 | 11:41 PM
siggyfreud's Avatar
siggyfreud
Yeah it really depends on how you enjoy driving it.
Old Sep 17, 2010 | 01:20 AM
UpTo11's Avatar
UpTo11
Daily driver, mostly speeds under 80mph.
Old Sep 17, 2010 | 07:27 AM
Cal26Stang's Avatar
Cal26Stang
Get coilovers lol
Old Sep 17, 2010 | 07:32 AM
Nuke's Avatar
Nuke
Tough one. I personally would go with the DS and gears but those suspension mods are tempting. If you're hooking up acceptably right now, I'd do the DS and gears first.
Old Sep 17, 2010 | 08:00 AM
Argonaut's Avatar
Argonaut
My car came with 3:55 gears, I first installed 4:10 and then a year later 3:73. At one time I also had Eibach Pro springs, Tokico D-Specs, J&M Camber plates, Sphoon PHB, LCAs and UCA in the car.
This was my first performance car. After buying it my first mods were Pypes Violators, CAI and Brenspeed tune. Next came the 4:10 gears. Looking back, I was very happy with the gears at the time, as are most folks. But then I got interested in performance driving: first autocross and then road tracks. So I went for the full suspension package as my next set of mods. After gaining a little experience what I quickly found out was 4:10 gears are horrible for my type of use - most AX courses are tackled in 2nd gear and I was hitting the rev limiter all the time. Most road courses are 3rd and 4th gear and my top speed was limited (for those who are going to say "just shift to 5th", its an overdrive and useless on a road course). So I switched back to 3:73 as a compromise - still has good torque but a little higer top end. Not only was this a better choice for my usage, having used both I like it better on the street also. With 4:10s you are out of first so fast its like...why bother, just start in 2nd. Bottom line is - I wasn't a big fan of the gears for my driving style and usage. In retrospect I would just stay with the 3:55.
On to suspension: As you can guess, I'll take suspension over driveline. The two "biggies" in suspension are the springs and the dampers. For a street car the other stuff (PHB, UCA, LCA, sways) has less impact on street handling (i.e. not at the limit) while adding harshness, noise and vibration (note that control arms along with reloc brackets do have a big effect at the drag strip but the OP stated his is a DD). Springs and dampers will significantly alter the feel and ride - mostly in a good way. The car handles better and inspires much more confidence, allowing you to drive more aggressively while still feeling in total control. On the other hand - any lowering spring is going to be stiffer, you feel every little bump and joint in the road surface...some like it, some don't.
So my advice is go for springs and dampers as your next mods.
Old Sep 17, 2010 | 01:11 PM
kenthicken's Avatar
kenthicken
For everyday driving, I'd go with suspension.
Old Sep 17, 2010 | 03:03 PM
grabber blue gt
I dont get why anyone is saying suspension. If hes driving the car everyday its going to have a much harder ride, and hes not racing on a AX track like Argonaut. Also for daily driving I dont recommend dropping the car, cause my 2010 is at the stock height and its still a pain in the ***, and I also have a friend who lowered his roush and just ripped his front splitter off pulling into a mcdonalds parking lot. But just like everyone else I have my own opinion
baddog671
Jul 26, 2016 01:20 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
Sep 17, 2015 07:32 PM
