Miles to Empty
Old Sep 21, 2010 | 03:28 PM
howarmat's Avatar
howarmat
s197 Junkie
no, you have 1 gallon left when it goes to 0, so when it says 50 miles to empty you really have MAYBE 70ish
Old Sep 21, 2010 | 03:57 PM
conejo172's Avatar
conejo172
I just have the base model so don't have miles to empty readout. But everytime I get gas I reset the trip meter. I drive a mix of highway/city stronger on the city part. And 9x out of 10 fill up right before the orange gas light comes on or very shortly after. Usually comes to around 13.6gallons put into the tank, and the trip meter around 285 miles/fillup. So if I had to guess once my light comes on I'm good for around 40-50 miles before running the tank "bone dry" which is a no no!
Old Sep 21, 2010 | 04:39 PM
datsyuk's Avatar
datsyuk
I got a 6 gauge cluster and don't see any red when it comes up?
Old Sep 21, 2010 | 05:02 PM
X3xMONGOOSEx3X's Avatar
X3xMONGOOSEx3X
same here
Old Sep 21, 2010 | 05:29 PM
alkemist's Avatar
alkemist
I haven't seen it myself either, but it sounds like the pot at the end of the rainbow, except it's the SOL pot when you see it come on.
Old Sep 21, 2010 | 05:46 PM
howarmat's Avatar
howarmat
s197 Junkie
happens sometimes when you have like 10 miles to empty
Old Sep 21, 2010 | 05:55 PM
bluovalguy's Avatar
bluovalguy
I've only seen my guage turn red once. When I test drove it at the dealer, they had run it almost completely empty. I've got the 50 miles left message, but it wont turn red til you well below that.
Old Sep 21, 2010 | 09:26 PM
07 Stang's Avatar
07 Stang
Originally Posted by replica
Is that on the fancy cluster? I have the 4 gauge cluster and I've never seen it go red.
Yep, 6 gauge and MyColor.
Old Sep 21, 2010 | 09:31 PM
Unleashedbeast's Avatar
Unleashedbeast
Originally Posted by 07 Stang
Did the display light up in red? Mine does when you get close to being empty
Mine does, when I get to 6 miles to empty on the message center.
Originally Posted by howarmat
except you have a 16 gallon tank and empty or 0 is actually at 15 gallons
True statement. I've actually driven my car beyond 0 miles to empty by 3-4 miles, filled up my car, and still had .5-.75 gallons to spare. The miles to empty is setup with reserve fuel in mind so that people are less likely to run out of gas.
Originally Posted by Nuke
The percentage of S197's (and just about most cars) with accurate on-board mileage data is very small. Aproximately 80% or more of the on-boards are off by about 2 MPG mainly due to their inability to properly calculate the amount of fuel used/remaining. IMO, with experience you can tell within 1 gallon what's in your tank based on the fuel gauge. As much as I'd like to rely mainly on the on-board, it's simply more inaccurate than my "guesstimate" based on the gauge.
I'm not saying there aren't any that are accurate. My g/f's '06 is nearly dead-on at each fill-up; gallons used and average MPG (compared to hand calculated). But hers is the exception based on all the input over my 3 years on this forum and others.
Mine was way off until I properly calibrated the tire rotation per mile and rear end gear ratio settings with my tuner. It was all wrong from the OEM, but the tuner fixed it. Now it's within 1-2% accuracy.
Old Sep 22, 2010 | 06:09 AM
jhawkr's Avatar
jhawkr
No. I filled up when it showed 36 miles to empty. It took 12.3 gallons to fill it up. That means I had 3.7 gallons left in my tank. I'm averaging 18.6 mpg. 3.7 x 18.6 = 68.82 miles to empty. That's roughly twice what the computer says.
The yellow pump turning to red? I really doubt that ever happens!
