Engine stops while driving
Old Nov 6, 2010 | 02:33 PM
157dB's Avatar
157dB
Cut & Paste Expert
If a 'diode was bad', the voltage would not 'be fine'.
All you have bad is the diagnosis....
Is the amperage 'fine' as well?
What did the output look like on the scope?
A bad diode will stick out like a sore thumb
on a silly scope.
Old Nov 6, 2010 | 06:20 PM
AlloySixxer's Avatar
AlloySixxer
I dont know...
Dealers suck but I can't drive the car far enough to get it somewhere else without it shutting off.
Old Nov 7, 2010 | 08:47 AM
157dB's Avatar
157dB
Cut & Paste Expert
People have been known to diagnose their own problems and fix them without the dealers help.
Still under warranty, are we?
Old Nov 7, 2010 | 09:17 AM
2005Redfire6's Avatar
2005Redfire6
They will probably blame it on the xcharger even if he is still under warranty and it could be something completely irrelevant!
Old Nov 7, 2010 | 01:51 PM
AlloySixxer
Over 3 years old, so no warranty. I'll let them finish their diagnosis tomorrow but they're not going to do the work on the car.
Old Nov 8, 2010 | 07:54 AM
AlloySixxer
Ok they said my problem is a bad alternator/bad diode. They want $630 to replace it. In the meantime, I'm gonna try to drive my car home from the dealer (5 mins).
Can't I just buy a new alternator and self install it for a lot cheaper? Should I get one better than the stock one? I don't know very much about this part.
Old Nov 8, 2010 | 09:50 AM
howarmat's Avatar
howarmat
s197 Junkie
replacement alternator is 230-260 probably unless you get a re-manufactured one and install is all about how much you know but it shouldnt be the hardest job in the world. its probably a 3-4 hour job so the dealers quote isnt totally out of line. I had mine replaced in my old truck for 400 from a dodge dealer. the labor was around that long i think
Old Nov 8, 2010 | 10:36 AM
AlloySixxer
So it really could cost this much..
C'mon guys I need advice on what I should do now that I know the problem!
Cherokee Ford quoted me $466, which would be a lot more reasonable.
Old Nov 8, 2010 | 10:52 AM
howarmat's Avatar
howarmat
s197 Junkie
466 isnt bad, especially using a brand new alternator. Its hard to say not know the funds you have available. give a local shop that your trust a call and see what they quote you
Old Nov 8, 2010 | 11:07 AM
AlloySixxer
Well, I would pay $466, figuring $250 for the alternator and $100 x 2 hrs for labor. I just don't want to have this problem again since I only have 25k miles and my alternator went out. Should I consider aftermarket options?
