Engine stops while driving
Old Nov 5, 2010 | 06:33 PM
AlloySixxer's Avatar
AlloySixxer
Default Engine stops while driving
Ok guys another problem today...
I was driving down the road and my engine just stopped out of nowhere. I tried to start it right away, but it wouldn't work. After a few minutes, it started and I drove to an Autozone nearby for a battery test. The battery was 100%(replaced last month), but he said the alternator had a low output. I tried to drive without A/C, radio, and lights, but the same thing happened on the way home, and I barely rolled it into a Ford dealership. All I get is a check engine light. They'll be doing a diagnostic in the morning...
All the belts spin and the engine is so close to turning over, but it just doesn't make it unless I give the car a 20-30 min break. Did I toast the alternator with all the new stuff (nav, sub, gauges, supercharger)? Anyone else have this problem?
Old Nov 5, 2010 | 07:25 PM
2005Redfire6's Avatar
2005Redfire6
Alloy, you always seem to fail man. Hopefully it's nothing serious.
Old Nov 5, 2010 | 10:43 PM
Nuke's Avatar
Nuke
Considering the chronic issues with the charging system (alternator and battery) in our S197's, I can't say I'm not terribly surprised. I doubt any of your electronics would have been the cause of failure on any HEALTHY electrical system but one that was operating below specs would simply fail sooner from the extra demand. Let us know what the stealer comes up with.
Old Nov 6, 2010 | 04:59 AM
howarmat's Avatar
howarmat
s197 Junkie
alt is probably shot with the new stuff and previous years of use
Old Nov 6, 2010 | 09:13 AM
2005Redfire6
I'm just anxious to see what they come up with .
Old Nov 6, 2010 | 09:55 AM
157dB's Avatar
157dB
Cut & Paste Expert
one word
subwoofer
overloaded the 135A OEM alternator
get the proper size in there or its the same deal down the road
www.PAperformance.com
Old Nov 6, 2010 | 11:13 AM
2005Redfire6
Originally Posted by 157dB
one word
subwoofer
How so? I ran two 10s back there for a few months and a 12 for a month or so with no problems.
Old Nov 6, 2010 | 11:52 AM
AlloySixxer
one word
subwoofer
So which one do I get instead? And could I self install one?
Old Nov 6, 2010 | 12:00 PM
157dB's Avatar
157dB
Cut & Paste Expert
When you say you ran them, was this 100% amp draw for the full 12 months
or 24 hours times 30 times 12 =s 8640 hours?
Or just intermittent amperage draw lets say for just the bass hits?
Can you translate the actual bass hits into a real hour clock to
give me a real indication of how much amperage you were really drawing
for this 12 months period. What was the amplifies duty cycle, roughly?
10" subs means nothing to me as to amperage draw on the alternator.
Whats the amperage draw of the SUBWOOFER AMPLIFIER (brand, model #??)
Old Nov 6, 2010 | 12:31 PM
AlloySixxer
Just got off the phone with the dealership. They said the alternator voltage is fine. The car starts as of now. Something is cutting it off though. He said a diode in the alternator could be bad, but the engine tech can't find the problem. The electrician won't be in until Monday. I can wait or I can try to drive the car home from the dealership (5-7 mins) and go from there.
