ATTENTION CAI OWNERS
When you installed your CAI and they made you relocate the power steering container, did anyone get a kink in the line like this? I need help cause my powersteering gets tight sometimes and I was wondering if this is the cause
vvvv
vvvv
1) i didnt have to relocate anything when i installed both mine
2) that isnt right at all
you messed up in the install somehow, granted this is a 2010 and is a little different but still seems a little bit messed up
I installed it a few months ago, and this is exactly how it is showed in the diagram (where its supposed to be)... It seems that the hose is a few inches too long, should I cut an inch off?
I'm surprised that the diagram didn't say to cut the stock tubing, if it seems too long. However, if you're positive that you installed it the correct way, than there shouldn't be a reason you can't cut it. If for whatever reason you need to extend it again, you can buy it at NAPA for a few dollars.
mudflap -- yeah I am going to do that first thing tomorrow after work hopefully it resolves my issue.
blacksmoke -- its the jlt, and I dont think its the heat shield because it happened before I even installed it, and it looks to be toutching in the picture but its not. The hose is just way too long
lincolnshibuya
12-08-2015 04:37 PM
