Got dynod today
Old Nov 15, 2010 | 06:40 PM
  #21
09cs's Avatar
09cs
Originally Posted by onederful100
N2O.
but seriously. i wouldn't worry about 5-10 hp. every car will be different.
True, I'll get UDP and a new tune and try and get a dyno sometime again.
Old Nov 15, 2010 | 07:05 PM
  #22
gman73's Avatar
gman73
Originally Posted by AlloySixxer
I'm guessing it was a Mustang Dyno also? That will affect numbers..
No GTR uses a dynojet. If it was a mustang dyno, his numbers would be about 240 RWHP and about 255RWTQ.
Old Nov 15, 2010 | 07:12 PM
  #23
onederful100's Avatar
onederful100
if you have the FRPP tune, a custom tune from brenspeed or AM/bama or VMP, etc. will get you more power.
Old Nov 15, 2010 | 09:31 PM
  #24
09cs's Avatar
09cs
Yeah, I think that and some UDP will do me good
Which tune do you suggest?
Old Nov 15, 2010 | 09:49 PM
  #25
onederful100
i don't think you can go wrong with either brenspeed, VMP, or AM/bama.
i have a VMP tune and it works great.
i'm sure others will have their favorites.
Old Nov 15, 2010 | 09:59 PM
  #26
09cs's Avatar
09cs
Thanks!
Old Nov 16, 2010 | 12:38 AM
  #27
DRock's Avatar
DRock
Both cars were done on the same dyno so that is outta the question.
Old Nov 16, 2010 | 12:58 AM
  #28
Tylus's Avatar
Tylus
Your expecting too much man. The HP/TQ #'s you got are pretty decent. Get a real tune + UDP + some gears and enjoy the car. That will cost you about $1,000. The gears alone will feel like +30 RWHP, and the tune will really wake things up for you.
Otherwise, it really is time to up the ante to a blower if you want more HP
Originally Posted by 09cs
And I'm kinda disappointed with the results...
Best run was 276 RWHP and 291 RWTQ
those are actually pretty good #'s. Not sure what you are basing your estimates off of, but for a stock motor + CAI + craptastic FRPP tuning...you did pretty good
Originally Posted by Nuke
In all actuality, those numbers are about what I'd expect with the FRPP tune. The typical '05-'09 S197 stock puts down about 265 RWHP. The FRPP tune adds roughly 15 RWHP crank (basically the Bullitt tune) which is roughly 13 RWHP. So if I had to take a stab at your RWHP based on your mods I'd have to say about 280. Since the accuracy and repeatability of the dyno has known variance, it sounds to me like you're right on for your mods.
With a good custom tune you should be able to add about 8-10 RWHP. Toss in the UDPs and add about another 5-6.
1st words o' wisdom
Originally Posted by gman73
Regarding dyno numbers, your friend my have a factory freak
damn things are like zombies. each time you think they've all been put down another one pops up
Old Nov 16, 2010 | 09:59 AM
  #29
AMChrisRose's Avatar
AMChrisRose
That stuff is right on, in regards to FRPP calibrations. They are very conservative. You can do a better custom tune with a set of delete plates and/or underdrive pulleys, and you'll be throwing down just under 300RWHP or just over, depending on dyno and temperatures, etc.
Let me know if there's anything Bama can do for you!
Old Nov 16, 2010 | 10:35 AM
  #30
chub46's Avatar
chub46
I have a FRPP CAI/tune and Roush extreme exhaust. I know that it is probably FRPP that is hurting me. But still, a friend who has no engine mods dynod with higher numbers, so didn't think the tune would make me LOOSE power.
Those are pretty good numbers. I have a bullitt and my stock dyno numbers were 275 rwhp and 285 rwtq. My stock 1/4 mile best time was 13.69 @ 105 mph. With the CMDP and tune my numbers were 289 rwhp and 307 rwtq.
