Finally! Blower install...
I'm doing this myself once I find out the right way that works to drill this hole which I am coming up on good info now, stay tuned!
hey just a reminder , make sure you blow out your engine real good where the fuel rails are , inspect to insure they are clean , you don't want any dirt getting in the engine when you change your injectors , also dap a little oil on the injector oring seal
Yes thats what the instructions say about the oil on the replacing injectors, I have also replaced the o-rings on all the injectors.
$550 isn't too bad for the install. Mind PMing me who gave you which quotes? I'm just interested in local performance shops' prices.
But these motors are easy to work on with good instructions, so that's why I did a self-install. You'll be able to do it easy once you have the right tools. When do those pieces come in? Give me call if you need an extra hand during the install. Me and some buddies can always stop by since you're close...
I think I am just going to get it installed by Kurgan motorsports in Braselton... After my should be $200-$300 belt tensioner my friend messed up I can't afford for anything else to go wrong so I am going to get it installed.
wow, 2-3 hundred for a belt tensioner is way too much. How did he mess it up?
http://www.brenspeed.com/555-3347.html
Thats what I run. $125 and very good unit.
