Car and Driver's Lightning Lap
beefier sway bars.
The significant factors that would have an effect on lap times are tires and gearing. Remember, the V6 was bouncing off the limiter and has a 6-speed. I suspect that the combination of gearing (trans & diff) and tire in the V6 was well suited for that track.
In any case, it is impressive. I must try to drive a '11 V6 soon. I am curious.
Better weight distribution, better/same suspension, better transmission. If it hadn't been hitting the speed limiter for 15 seconds, it probably would have beaten the '10 GT by a couple more seconds and been on the heels of the '11 GT. For the first time in Mustang history, the V6 is actually a viable performance option and is competitive with the imports of the same class! No longer does it need to be compared to Civic Si's, Nissan Sentras and such.
Assuming the driver is a wash....
other than that the V6 PP has the same suspension, brakes, and tires of the '10 GT TP so the only variables are: weather, driver, transmission
(although i think the 3.73 in the '10 GT may be more aggressive/equally aggressive to the 3.31 in the V6)
and i believe the two cars have about identical weight distribution. either way i expected the lap times to be close (slight edge to the '10) but i was completely surprised that the V6 PP beat it by almost a full second (2 second if it didnt have a speed limiter)
