was pypes a bad decision? are all aftermarket exhausts like these?
Old Jan 6, 2011 | 11:18 PM
bakerjd's Avatar
bakerjd
I have had no problems with my Pype Bombs but then again I haven't been in an accident (KNOCK ON WOOD). If it rattled with the stock mufflers, it's not the mufflers.
Old Jan 7, 2011 | 01:14 AM
LTDan's Avatar
LTDan
Originally Posted by ChrisIA
heat shield.
I second this one. Take a good look at all the heat shielding between the exhaust pipe and the body of the car. They come loose rather frequently.
Old Jan 7, 2011 | 02:32 AM
Fifthwind's Avatar
Fifthwind
So it rattled with the stock mufflers after an accident and it still rattles with the MDs on it... That means that the problem is farther up the pipe then.
A common problem is the exhaust hangers that are on the transmission crossmember. There is a TSB on it as well, but yours might have been loosened because of the crash. It's easy to fix by securing the hangers with a 3" worm-clamp. I Attached the TSB below... it might be something to check.
I performed this TSB myself and it got rid of a rattle I had been bothered by for a long time.
Good Luck.
**BTW, I run a Pypes exhaust myself and have been very happy with it.
File Type: pdf
Old Jan 7, 2011 | 03:50 PM
m5miler's Avatar
m5miler
thanks man, i printed that off and i'm gonna give it a shot and try to see what the problem is.
Old Jan 7, 2011 | 03:58 PM
Nuke's Avatar
Nuke
Don't forget that any metal-to-metal contact on any part of the exhaust will be heard at the tip. Didn't you ever see the indian with his head to the train track? Oops. Forgot how young some of you guys are...
Old Jan 7, 2011 | 05:04 PM
grabber blue gt's Avatar
grabber blue gt
I agree with nuke, get under the car and check some things out and try and solve the problem. I just installed my borlas in about 30 mins so its not going to take long. I had a rattle when I had my roush system (muffler deletes) and it turned out to be a loose muffler hanger. Start there
Old Jan 7, 2011 | 05:22 PM
m5miler's Avatar
m5miler
thanks man, i'll check that out. i have a feeling it is a loose hanger.
2007CalSpec
Dec 13, 2020 11:42 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Emblazoned
Sep 3, 2015 10:45 PM
