02 sensor question?
Old Jan 24, 2011 | 05:18 PM
JRamagost's Avatar
JRamagost
Default 02 sensor question?
Ok guys, I have a 05 GT Vortech Charger, it has BBK longtubes,BBK X pipe with cats,magnaflow pipes. The long tubes have extensions on the sensors and I dont have any in the rear. What can I do to fix this to get an inspection.
Old Jan 24, 2011 | 06:31 PM
tx_zstang's Avatar
tx_zstang
1. put in rear o2 sensors past the cats (the proper ones; they are different from the fronts).
2. connect them up, use pulg-in extensions, hard-wire in the needed length, etc.
3. change the tune to turn the rear sensors on.
4. drive around on them a few days and make sure no CELs.
Old Jan 24, 2011 | 08:29 PM
SpartaPerformance's Avatar
SpartaPerformance
Is the x-pipe drilled for rear o2's? If so is the bung welded or screwed shut? Basically buy 2 more extension harnesses re install your O2's providing you have them and change your tune as stated above and you should be good to go.
Jb145700
Aug 21, 2022 06:37 AM
04stangman
Sep 17, 2015 01:45 PM
Big Al's 03
Sep 16, 2015 07:31 PM
TfcCDR
Sep 14, 2015 12:08 PM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
