maximum tire width
Old Jan 27, 2011 | 06:33 AM
2005Redfire6's Avatar
2005Redfire6
Originally Posted by Nuke
Better rubber and some suspension mods.
+1, get some LCA's and a UCA.
Old Jan 27, 2011 | 06:46 AM
05 Mustang's Avatar
05 Mustang
A 305 is probably as wide as I would go....but since different tire manufacturer's tires actually measure in size differently, I'd choose a good tire as others have mentioned and then look at the dimensions to see how they measure up.
ex: A buddy of mine bought a 295 in one brand for his vette that measured the same as a 305 in another brand.
Old Jan 27, 2011 | 06:50 AM
2005Redfire6
This is true... My buddy has good year F1's 255's and they look sooo much wider then my sumitomo 255s.
Old Jan 27, 2011 | 07:19 AM
Diabolical!'s Avatar
Diabolical!
If you're doing it for looks, then by all means jam whatever you can in there, but if it's for performance, I really don't think anything bigger than a 275 out back is necessary. My drag tires are 275/60/15s, but my street tires (all about looks) are 28x12x15. That's as big as I could go without cutting the bump stop brackets.
Old Jan 27, 2011 | 08:59 AM
Bmr4life's Avatar
Bmr4life
You need better rubber and suspension mods.
Old Jan 27, 2011 | 12:15 PM
nmd55's Avatar
nmd55
you can probably get away with 315s, but i would stay at 305s.
You can always send your wheels to weldcraft get them widened to 12" and run 335s.
That is what I am having done with my super snake alcoas!!
Old Jan 27, 2011 | 02:03 PM
Diabolical!
That's gonna be a tight squeeze between the fender and the wheel well. I haven't seen anyone fit better than a 325.
Old Jan 27, 2011 | 03:14 PM
05 Mustang's Avatar
05 Mustang
That's awesome...then you'll be able to install 335/30/20's!!
Old Jan 27, 2011 | 06:30 PM
Sikest's Avatar
Sikest
Originally Posted by Recon111
Wider tires don't equal better traction, with same compound, a smaller tire will give same traction.
What?? Of course a wider tire provides more traction. The larger the contact patch the more friction the tire creates between your vehicle and the road surface. Perhaps a trip back to physics class is in order.
I will agree that switching to a softer compound at this point makes more sense that stuffing something too large under the rear fenders.
T.
Old Jan 27, 2011 | 06:40 PM
Unleashedbeast's Avatar
Unleashedbeast
Originally Posted by Diabolical!
You can fit up to a 325 width tire with the right offset and removal of the bump stop brackets.
Correction:
You can fit a 335/30/18 Nitto 555R drag radial on a 18x11" +45mm offset wheel (i.e. - SVT GT500 rim widened by Weldcraft) with no modifications. This has been confirmed on a few Shelbys at SVT performance forums.
I'm going to use Mickey Thompson 345/35/18 ET Street drag radials, and will only require the removal of the shock dust cover/boot. Here are a few threads about the top.
My personal 18x11" thread
ModularFords - Nitto 335/30/18
SVT Performance - 335/30/18
SVT Performance MT ET Streets 345/35/18
