maximum tire width
Old Jan 26, 2011 | 05:59 PM
Wally39's Avatar
Wally39
Default maximum tire width
Anyone know the maximum tire width I can put on the rear of my 2011? I have 285's right now on 18x10 rims and I still have traction problems when I take off fast.
Old Jan 26, 2011 | 06:25 PM
ikemikestang's Avatar
ikemikestang
I doubt going any wider will give you any more traction. What type of launch or "take off" are you doing?
Old Jan 26, 2011 | 06:32 PM
Recon111's Avatar
Recon111
Wider tires don't equal better traction, with same compound, a smaller tire will give same traction.
Old Jan 26, 2011 | 06:50 PM
908ssp's Avatar
908ssp
You can put a 315/35 on a 20"x11". You don't want to go over 295 on a 10" rim.
Old Jan 26, 2011 | 06:56 PM
onederful100's Avatar
onederful100
i have 295/45's on a 10" wide rim with 42 offset
you should try better tires if traction is an issue.
Old Jan 26, 2011 | 07:17 PM
Milspec's Avatar
Milspec
Should be able to go up to a 315/40/18....I know this isn't a 2011, but should work the same.
Old Jan 26, 2011 | 07:22 PM
onederful100
what tires do you have now?
try some Nitto NT05's.
Old Jan 26, 2011 | 07:42 PM
Nuke's Avatar
Nuke
Better rubber and some suspension mods.
Old Jan 27, 2011 | 02:32 AM
Diabolical!'s Avatar
Diabolical!
You can fit up to a 325 width tire with the right offset and removal of the bump stop brackets.
Old Jan 27, 2011 | 02:58 AM
grabber blue gt's Avatar
grabber blue gt
there are gt500's out there running well over 500rwhp that dont have anything bigger than 285's on the back. Try some better rubber, like already mention the NT05's. You can also try some LCA's but the bigger the tire doesnt always mean more traction.
