Sponsored by:
Sponsored by:
Short antenna recommendations?
Old 01-01-2007, 07:17 PM
07AlloyGT
07AlloyGT's Avatar
Default RE: Short antenna recommendations?
ORIGINAL: Back in Black
I got this one and it works nearly as well as the stock antenna but looks a hundred times better.
http://www.mustangtuning.com/8fiblan.html
thanks. just ordered.
07AlloyGT is offline
Old 01-01-2007, 07:35 PM
mlcrycc
mlcrycc's Avatar
Do you even need that antenna on the fender if you have satalite radio? ive always wondered because there are 2 seperate antennas. If I dont need it thenill just get rid of it.
Nope. Separate antenna for satellite.
mlcrycc is offline
Old 01-01-2007, 08:02 PM
howarmat
s197 Junkie
howarmat's Avatar
+1 to the 8 inch from american muscle
http://www.americanmuscle.com/8fiblan.html
I get the same reception as before and looks great!
howarmat is offline
Old 01-01-2007, 08:58 PM
awakeinAZ
awakeinAZ's Avatar
Looks like you're all set. If I were going to do it again I would get a 14" which would meet the top of the windshield.
I got mine here, works great, ain't cheap!
http://www.ssinserts.com/index.php?m...products_id=53
awakeinAZ is offline
Old 01-01-2007, 09:15 PM
moosestang
moosestang's Avatar
correction to my earlier post. This is the antenna I got.
http://www.americanmuscle.com:80/bialshan.html
it says 13 inch, but from the base to the top is 13 and 3/4th inches. The reception is the same as stock for me.
I'll take some pictures of it tomorrow to post in this thread.
moosestang is offline
Old 01-01-2007, 09:18 PM
07AlloyGT
07AlloyGT's Avatar
ORIGINAL: awakeinAZ
yeah, i just sent an email to american muscle getting them to change my order from the 8" to the 14" version. i like the streamlined look on the longer antenna.
Old 01-02-2007, 05:34 AM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Bought the same one on Ebay and have no issues with it! I do live in a very populated area with many local radio stations and have no signal problems as of yet!
mygt500 is offline
Old 01-02-2007, 09:59 AM
redfireshaker06
redfireshaker06's Avatar
Did the same thing probably 5 times now for myself and different people. Just in case. Use JB weld. That ball will not go anywhere.
ORIGINAL: MACHINE
just did a simple DIY job...no major skill involved. Some quick instructions...
Take your stock antenna and mark the height at which you want it to sit...
Remove the antenna and place it in a vice
Take a set of pliers, wrap a rag aorund the ball-end of the antenna and pop the ball off - dont let it roll away!
Cut off the antenna at the mark you placed earlier
Grind the tip of the antenna to allow for the ball replacemant
Replace the ball on the end of the antenna - might need to tap it lightly to get it seated properly...
I've experienced no reception issues...
redfireshaker06 is offline
Old 01-02-2007, 02:19 PM
sandy
sandy's Avatar
Subzero, I did exactly what "MACHINE" describes; Icut mine to 18". Looks lots better withno loss in reception.
sandy is offline
Old 01-02-2007, 02:29 PM
Fireguy28
Fireguy28's Avatar
I have the same antenna LOOKS great and it works just as good as stock even though i dont listen to the Radio that often.....
Fireguy28 is offline
Quick Reply: Short antenna recommendations?
