Is taking it to 6k rpm once in awhile ok?
Old May 19, 2011 | 11:12 PM
Will3212's Avatar
Will3212
Default Is taking it to 6k rpm once in awhile ok?
I have a 12' mustang gt stick. I only have 300 miles, however, I took it to 6k rpm in 2nd gear 4 or 5 times already. People say the new engine is still breaking in and taking it up that high in the rpm range is bad for the engine is this true? I hope I didn't damage my engine i'm worried to be honest. I never red lined it and the highest I took it to was 6k rpm maybe 5 times.
Old May 19, 2011 | 11:37 PM
Adam's Avatar
Adam
You're fine.
Old May 19, 2011 | 11:45 PM
KonaStangPete's Avatar
KonaStangPete
you should be good, but i'd take it easy til you at least hit 500mi
Old May 20, 2011 | 12:03 AM
808muscle's Avatar
808muscle
I had always read where you need to break the clutch in for 500 miles so high revs would be a no no until then.
Old May 20, 2011 | 09:02 AM
hawkeye18's Avatar
hawkeye18
No.
High revs don't affect the clutch any different than low revs do. What you are not supposed to do for the first few hundred miles are:
1) Dump the clutch at high RPMs
2) Powershift
I am a firm believer in the "break it in like you stole it" method, which I performed on my '12 MT. It runs like a champ.
These engines are 90% broken in within the first 30 seconds of operation, which happened before you ever saw the car at the factory.
Old May 20, 2011 | 11:02 AM
corruptor's Avatar
corruptor
Now that you're at 300 miles, I recommend at least a run to redline every 100 miles or so. Let the engine revs fall naturally back to 2-3K (i.e., don't redline then brake immediately). I've had success using this method which supposedly helps seal the piston rings and avoid future oil burning situations.
Old May 20, 2011 | 01:00 PM
GTjoe49's Avatar
GTjoe49
I'm with Hawkeye. I am of the old school that says drive it out of the showroom the way you are always gonna drive it.
I have been doing this to new cars for 39 years and haven't lost a motor (or clutch) yet!
Old May 20, 2011 | 01:23 PM
MustangFirstCar's Avatar
MustangFirstCar
You are supposed to vary the RPMs when breaking it in. I don't know how good revving up really high is for it though.
Old May 20, 2011 | 01:27 PM
REDBOSS1's Avatar
REDBOSS1
It's a mustang, drive it like you stole it.....jjk. No seriously 6K is not bad I do it hard through 4th gear about once a week.
Old May 20, 2011 | 02:45 PM
SON OF 68's Avatar
SON OF 68
Agreed Hawkeye! Break it in like a beast and it'll be a beast. You gotta train em young! Whenever I've built a motor, I followed the 20 minute run for the cam, after that, wide open till ya see God, then brake!!
