Quick question
Old May 23, 2011 | 07:29 AM
bakerjd's Avatar
bakerjd
Originally Posted by Nuke
Also check the passenger side carpet by the kickpanel for moisture. Take a tissue and dab the carpet. Hopefully it's the door switch and not the "dreaded you-know-what" TSB issue.
Oh god, I hope not! That would be the absolute worst situation! I checked it and theres not a sign of any water (completely dry and no water residue) so that's good. I have no idea what's going on.
Could the door switch problem possibly be a fuse issue?
Old May 23, 2011 | 08:06 AM
2005Redfire6's Avatar
2005Redfire6
I think if it was a fuse issue it wouldn't work at all on the side, but hey what do I know .
And Rick, we finally agree!
Old May 23, 2011 | 08:39 AM
bakerjd's Avatar
bakerjd
^true, I was just throwing something out there...I'm just going to take it to the shop that installed the alarm system tomorrow morning after work. I'll let you know what's going on. If they can't help, i'll stop by the dealership.
Old May 23, 2011 | 11:18 AM
Nuke's Avatar
Nuke
I only mentioned the water leak TSB solely because the problem surfaced following the car being involved with water. I also do hope it's something less... severe.
Here's the link to the manual which includes wiring diagrams. You can drill-down to those for the interior lighting.
http://iihs.net/fsm/?dir=1
I'd ask the shop to mark-up the wiring diagram for where they tapped the alarm system in. It's called "configuration control".
Old May 23, 2011 | 11:45 AM
2005Redfire6
Baker, I have a Clifford system on my car that was put back in 2006 and I rarely have it armed mainly because its a PITA. I did have one occurence about 2 months ago where I was driving to work on the interstate and the alarm just went off, so I don't know where that came from!
shanec's Avatar
shanec
These cars are programmable in strange, undocumented ways.
Once I somehow programmed my car to lock the doors every time I turned off the engine and got out of the car. I think some combination of key-on/key-off and pushing the lock/unlock buttons did taht.
Old May 23, 2011 | 12:28 PM
mayo's Avatar
mayo
It has been dead at the shop so I took a look at the door. No mechanical switch was found in the door frame...guess that would have been too easy, right?
The switch has to be either in the swingarm that goes back in the door on the hinge side or on the rear latch when you close the door to tell the puter that it is closed. If it was a fuse I doubt the puter would even recognize the door was open at all, but at the same time it could produce an open circuit that would say it was open all the time...so idk.
I have had the old plunger style switches go bad a few times over the years and hosed them down with wd40 for a quick fix until I could replace them, so it very well could be the problem, but unforchanetly you will have to remove door components to find out.
Old May 23, 2011 | 12:59 PM
Nuke's Avatar
Nuke
After taking a quick look at the wiring diagram, is there any chance that you hit the dimmer switch for the dash lights? Turned full on, it turns on the dome (map) lights. It's happened before...
Old May 23, 2011 | 01:50 PM
bakerjd's Avatar
bakerjd
After looking at the diagram this morning I realized the same thing and yes, map lights problem solved but what explains the door issue? I'm lost
Old May 23, 2011 | 01:56 PM
MeanStang08's Avatar
MeanStang08
ChopShop Mod-tator
do you have a OBDII code reader / tuner?
