E brake issue
Old Jun 10, 2011 | 12:21 PM
spower's Avatar
spower
Ok was able to back the nut off so I am able to now pull the handle up a few clicks but it is not engaging the brakes, I can still move the car.
Old Jun 10, 2011 | 12:35 PM
Nuke's Avatar
Nuke
When you pull up on the e-brake handle, does it feel like it's getting stiffer (and that is NOT a sexual inuendo at the moment) as it moves up? You should be feeling some increasing resistance thru the e-brake handle travel.
Old Jun 10, 2011 | 12:41 PM
spower's Avatar
spower
Hahaha, funny....
Yeah sort of, I pull it up and it clicks about 3 times and then stops can't pull it anymore, but is not holding car. I tried tightening the nut a little while handle is in up position but no change.
Old Jun 10, 2011 | 01:16 PM
Nuke's Avatar
Nuke
In that case, you'll need to revert back to the service manual and continue troubleshooting if you feel capable. Otherwise, it's off to a shop. Good thing is you don't need a Ford dealership to check brakes.
Old Jun 10, 2011 | 01:33 PM
spower's Avatar
spower
Thanks for your time and help Duke!! Appreciate it.
Old Jun 10, 2011 | 02:04 PM
spower's Avatar
spower
Anybody else have advice or a manual??
Old Jun 10, 2011 | 02:32 PM
Nuke's Avatar
Nuke
I find it hard to beleive that this doesn't help with the troubleshooting. The e-brake is a pretty simple system. http://iihs.net/fsm/?dir=108
Old Jun 10, 2011 | 02:51 PM
spower's Avatar
spower
Did you read through it? It is not that helpful really, very basic.
Old Jun 11, 2011 | 10:36 AM
spower's Avatar
spower
Still looking for some help, was able to loosen the nut so now the handle will raise up about 3 clicks but it is not engaging the brakes, car will still roll. Any ideas?
Thanks!
Old Jun 11, 2011 | 10:40 AM
pascal's Avatar
pascal
S197 Section Modder-ator
Lol, Duke.
Duke Nuke 'em FTW!!
