06 V6 upgrading to 05 GT
i asked him if he knew it if had an water leaks near the front of the passenger side he said it did not, but sellers could lie. The car is 3 hours away so oncei sell mine im going to tke a certified check with me that way i can buy it if i want it and if not i can jsut rip the check up
The heat shield rattle is very common but I've never had it so I can't say how easy the fix is. As far as the water leak, if he won't let you run a garden hose on the front windshield/passenger door area for a few minutes, then let you remove the access panel in the passenger kick panel to feel above the SJB and down at the carpet for evidence of moisture, walk away; it's one nitemare you don't want to deal with.
Pascal, you mind reader, you...
Price seems in line with most '05 with average mileage. Although the '05s seem to have the most teething problems of 2005-2009 cars(I owned a '05 and now have a '06). The gas tank filling issues, bad throttle body, eating batteries, dash rattles, passenger door weather strip leaks and I'm sure there's more, but these were the issues I had with my '05. My '06 has only had bad axle bearings & faulty fuel pump(both covered under warranty). I'd say buy a newer model for that price
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
