anyone have either tuner?
the sct livewire
or the sct tsx
as I go FI I would like to be able to know what's going on with my engine, but hate gauges and gauge pods and was hoping this/these may be my answer...opinions? Accuracy?
or the sct tsx
This looks like it has everything I'd need, and I'm assuming the info. comes electronically from obdII port rather than the traditional method of incorporating sensors and guages...Off to research it now...
so I don't get it...With either of these are the signals/readings/data collected such as A/F ratio, rpms, timing, boost, ect sent to the sct thru the obdII port, or do I still have to tap into the fuel rail, vac hoses, ect (or however gauges are hooked up? This seems much more difficult than it really is I hope! I just want to plug into the obdII and read my A/F ratio...
third time typing this, sweet...fkin 404...anywho, this is too good to be true...here's what you can do with it, UNLESS YOU HOOK UP CABLES, ECT like normal gauges, FTL...
• Intake Air Temperature
• Desired Idle RPM
• Engine Coolant Temperature
• IAC - Idle Air Conrol DC
• Throttle Position Counts
• Long Term Fuel Trim Bank 1
• Long Term Fuel Trim Bank 2
• Short Term Fuel Trim Bank 1
• Short Term Fuel Trim Bank 2
• Desired Idle RPM
ernesto-619
Sep 10, 2015 01:32 AM
