quick maybe stupid question
Old Jun 22, 2011 | 12:39 PM
Ford_Dude's Avatar
Ford_Dude
Default quick maybe stupid question
ok I might already know the answer to this and I'm just hoping I'm wrong
my new tires should be arriving tommarrow and I've picked the place I'm going to have mount and balance them
ok they're 255/45-18 and 285/40-18
1. as its an auto (please no flames fo getting an auto back in 2006 as I hadn't had a chance to learn stick and didn't want to learn on a nice car) ok so do I need to get bama/AM to revise my tunes for the slight differance in tire size? or will just editing it in the sct be good enough?
2. (and this is the one that has me worried) will I need to go to an alignment shop? I'm guessing its a sadily yes
Old Jun 22, 2011 | 12:54 PM
jwharton's Avatar
jwharton
I don't know why you would have to have it aligned if you were not having problems before. The SCT will correct your speedo, you don't need a new tune.
Old Jun 22, 2011 | 01:09 PM
pigeon smasher's Avatar
pigeon smasher
I did the same and I think my SCT had a section that allowed me to go in and tell it the new tire size. That was it. No new tune needed.
I got an alignment. 3 years later the treads are still even and tires haven't been rotated.
Old Jun 22, 2011 | 01:18 PM
Ford_Dude's Avatar
Ford_Dude
I was slightly worried about alignment due to the slightly differant size
as for the tune I wasn't sure if the transmition part of the tune would make use of the updated tire size or if the shift points could be off ever so slightly
thanks for the info I guess I'll just be sure to grab my SCT in the morning
oh also should I enter int he rear or the front tire size in the sct?
I know the rears are the drive wheels but its my understanding that the ABS sensores are used now for speedo and as such its in theory possible to use the ABS data from the fronts
ok I might just be over thinking it and worrying for nothing I do that sometimes when theres a shread of doubt
Old Jun 22, 2011 | 01:41 PM
Franchi's Avatar
Franchi
Nah you be fine. Dont worry about it.
Old Jun 22, 2011 | 01:52 PM
Ford_Dude's Avatar
Ford_Dude
oh btw the wheels I got are
front http://www.americanmuscle.com/black-...18x9-9410.html
back http://www.americanmuscle.com/black-...8x10-0510.html
and the tires are
Nitto NT555
Old Jun 22, 2011 | 02:35 PM
shad2009's Avatar
shad2009
why are you having a place mount and balance them?...AM does that for you for free...and you can change the tire size right on the tuner
Old Jun 22, 2011 | 02:42 PM
Nuke's Avatar
Nuke
No impact on alignment.
The SCT tuner allows you to make tire revs per mile changes to account for differences in tire OD. Just get the manufacturers specs and compare that # to what you're tune currently has it set for. My old SCT II allowed changes in 10 RPM increments.
Old Jun 22, 2011 | 02:55 PM
Ford_Dude's Avatar
Ford_Dude
Because AM didn't have the tires I wanted
Tivo304
Aug 28, 2023 12:19 PM
tmdm
May 2, 2021 02:49 PM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
