shut off
Old Jun 26, 2011 | 04:06 PM
skip emel's Avatar
skip emel
Default shut off
i was driving my daughter 07 4.0 stang, it shut off in the road
battery as full charge, but went turning key nothing happens
i found a amp wire in the truck still hooked to voltage, think it grounded out
something, any ideas, thanks
Old Jun 26, 2011 | 08:32 PM
2005Redfire6's Avatar
2005Redfire6
Oh wow.... Sounds like possibly an alternator by the information given...
Old Jun 26, 2011 | 09:30 PM
skip emel's Avatar
skip emel
Default shut off
no car still has battery voltage, after checking, i found no voltage at
white/yellow wire to ingition switch, but i don't known if it has any fusible links
can,t find any wiring inof on line
Old Jun 26, 2011 | 11:10 PM
tx_zstang's Avatar
tx_zstang
then you didnt look in the right place...
http://iihs.net/fsm/?dir=40
Old Jun 27, 2011 | 07:04 AM
Nuke's Avatar
Nuke
If the battery is good, the engine should crank despite a failed alternator (which isn't that uncommon; the charging system on these S197's are subpar). It sounds like you know your way around circuits to some extent so hopefully the wiring diagrams included in the link previously provided will help.
Please post your results. And welcome to the forum.
Old Jun 27, 2011 | 01:36 PM
Derf00's Avatar
Derf00
Gentleman's Relish
When you say "nothing happens" do you mean the fuel pump and dash lights stay off when the key is turned to the "ON" position?
Old Jun 27, 2011 | 06:07 PM
skip emel's Avatar
skip emel
Default shut off
yes no power to dash, or key switch,car wont spin over, i also found
fuse block in right side kick panel as to power/volts to fuse #12
which is climate control/ignition,
Old Jun 27, 2011 | 06:08 PM
skip emel's Avatar
skip emel
i mean as no power or voltage to fuse #12
BOB ROME
Jul 26, 2023 01:54 PM
Seanam
Oct 4, 2015 10:15 AM
dalehunter
Sep 25, 2015 10:51 AM
smiller38
Sep 16, 2015 07:59 AM
