Shaker 500 Audio Problem
Old Jul 1, 2011 | 12:56 PM
eleanorownerdaddy's Avatar
eleanorownerdaddy
Default Shaker 500 Audio Problem
Son's 2006, V6, Auto. Trans., Mustang is equipped w/ Shaker 500 system. Three days ago the unit suddenly ceased audio output when transmission is in any of the drive gears. Engine on/off does not matter. When in neutral or park, it works okay. Anyone else experience this? Baffles the hell outta me.
Old Jul 1, 2011 | 02:04 PM
BigDinTexas's Avatar
BigDinTexas
Waterleak possibly? Is/has the passenger floor carpet been wet recently? Have you gotten much rain there? I would search the forums for the waterleak TSB (technical service bulletin) and SJB (smart junction box) and read up... The corrosion can cause electrical gremlins...
Old Jul 1, 2011 | 02:41 PM
Nuke's Avatar
Nuke
Wow, that's a new one...
Check out the wiring diagrams here: http://iihs.net/fsm/?dir=1
I'd look it over myself but I'm heading out shortly.
Old Jul 2, 2011 | 09:08 AM
157dB's Avatar
157dB
Cut & Paste Expert
There is nothing tied together electrically between the drive selector
and the sheitter 500. The sheitter is a stand alone unit except for
the speed volume function.
http://iihs.net/fsm/?dir=40&viewfile...Navigation.pdf
http://iihs.net/fsm/?dir=40&viewfile...ls - 5R55S.pdf
My best guess is the SJB has suffered from the dreaded water leak.
Try disconnecting the negative terminal of the battery for 20 minutes and
then do the adaptive relearning procedure described in the owners manual.
Old Jul 7, 2011 | 09:03 AM
eleanorownerdaddy
Wow, thank you all. The water leak was one thing I had not thought of. It could very well be the problem. Two days after the original post, the radio started working fine again. Had no rain either, though. Did not notice any wet carpet, but I'll be keeping a closer eye on that. Thanks, y'all
uberstang1
Sep 20, 2015 06:42 PM
04stangman
Sep 17, 2015 01:45 PM
cbird1177711
Sep 3, 2015 08:43 PM
iamgobono
Sep 3, 2015 12:37 PM
cbird1177711
Sep 2, 2015 08:51 PM
