Plastic shield under front wheel well is loose 2006 GT
There are fender-splash-shield-pin-type-retainers, that holds the fender-splash-shield in place....look in the service manual for the p/n.
http://iihs.net/fsm/?dir=434&viewfil...h%20Shield.pdf
PS. Buy some extra ones and send me some...just for spares
There's only a handful of weight reduction mods that net big savings. Driveshaft,wheels,swaybar,jack & spare then rear seat delete(pending you dont need the rear seat).Then its high dollar weight savings in front end suspension. after that it is all nickel & dime weight reductions which all add up. I had cut 250 honest pounds with deleting items such as the wheel skirts. For a guy like me who cares only about 1/4 mile performance thats just another 5lbs off the nose of the car which is where you want your weight savings(& rotating mass). So for you maybe it is stupid. For guys like me it is the end game result which is only done by these type of mods for weight saving.
When the pins fell out of mine I got new ones from Napa. Also used 3M tape around the pin holes between the metal and liner to help hold it tight. Rattled even with new pins and was driving me nuts.
Sep 3, 2015 07:14 PM
