noob coolant question
Old Jul 10, 2011 | 01:47 PM
siggyfreud's Avatar
siggyfreud
Originally Posted by Mikes_BLK_GT
Guys it's pretty obvious on the Roush blowers which system is which so no need for this really, Autozone carries water wetter, I have heard of water wetter leaving oily residue in your coolant after its been used awhile, try RP. I personally buy the antifreeze and mix with distilled water myself so I get the mixture I want. I'm probable closer to 45% antifreeze. Not sure about the anitfreeze's Autozone carries just make sure whatever you get is compatible for our cars.
You use different colors so when you walk out to the parking lot and you see a bunch of coolant underneath you know which system took a dump.
Old Jul 10, 2011 | 04:14 PM
JimC's Avatar
Super Moderator
Exactly - All intercooler systems will be separate systems - at least I've never seen one that shares the systems - so if it is spraying out of a hose while you are looking at it you know which one it is. But when all you see is a puddle under the car and coolant sprayed all over the engine bay, it isn't obvious which one is leaking.
Been there - and had to clean everything off and start trying to figure out where it came from since both reservoirs seemed low. After that - different colors so if it happens again I just need to look at the color and it will tell me which system needs attention and what hoses to start checking.
If you take a look at the GT500 you can see they usually have bright green in the intercooler and a pinkish color for the engine coolant.
Old Jul 10, 2011 | 06:59 PM
grabber blue gt's Avatar
grabber blue gt
Any particular brand I should look at? I was thinking of just getting motorcraft but god knows how much they over charge for it cause the name FORD is on it.
Old Jul 10, 2011 | 07:46 PM
moosestang's Avatar
moosestang
I wouldn't waste my money on water wetter, unless you use it instead of antifreeze. It's not going to make any difference. It doesn't mix well with the Ford coolant, ime.
I'd buy good old prestone antifreeze and do a 50/50 mix or 70/30 if you live where it's warm. Use distilled water.
Old Jul 12, 2011 | 12:41 PM
flash gordon's Avatar
flash gordon
Just make sure that you always use distilled water in the radiator to prevent minerals buildup.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
wraith777
Sep 28, 2015 10:49 AM
