NEED HELP FAST!!!!
Old Jul 13, 2011 | 12:09 PM
grabber blue gt's Avatar
grabber blue gt
Default NEED HELP FAST!!!!
I finally got my UDP's off and I am going to put the stock crank pulley back on but the steeda install bolt stripped at the end and the stock crank pulley bolt is to short to reach because the pulley isnt on enough!!!! My father said if its bad the holes just need to be re threaded which isnt hard but wtf how do I get the crank pulley on!!!!! HELP PLEASE BEFORE SOMETHING IS DAMAGED!!
Old Jul 13, 2011 | 12:42 PM
jwharton's Avatar
jwharton
I replied to your PM.
Old Jul 13, 2011 | 12:56 PM
siggyfreud's Avatar
siggyfreud
You just need to use a thread chaser on the crank, and to get a longer crank bolt. I believe they are torque to yield meaning you don't want to reuse them anyways.
The crank threads are generally very tough. I've yet to strip one on any engine I've assembled/helped assemble. Clean the threads with the chaser and you should be okay.
Old Jul 13, 2011 | 02:20 PM
grabber blue gt
Ok guys thanks for replying!!! Everything worked out fine and it just turned out that the steeda install bolt wasnt fully in so it damaged the first 2 threads on the bolt NOT THE CRANK, so I lucked out.
Old Jul 13, 2011 | 05:46 PM
tx_zstang's Avatar
tx_zstang
Rented one of the crank installers from local auto parts store, making sure the crank got on far enough before pulling it all the way in with the crank bolt. Getting it far enough to get the bolt started is a pita!
Bokeo
Oct 10, 2015 08:28 PM
stealth_GT
The Racers Bench
Sep 22, 2015 02:19 PM
ctgreddy
Sep 20, 2015 08:35 PM
Sep 16, 2015 07:53 PM
